qt-50 speedo
Teri /
I've got 2 running qt-50's - both yellow '82. The diff is that one sat out in the sun for 10-15 years, so that's the parts bike.
The better scooter was missing the speedo cable, so I pulled the one off the parts bike and hooked it up. Doesn't work going forward - but it DOES seem to register when the wheel is turned backward. Of course I pulled the cable out of the housing, used solvent to clean it well, and re-lubed with Phil tenacious oil, what I had on hand.
What's up with this? Can the little goodie that turns the speedo cable be stripped? Is there a way to test this? Common wear problem?
Any hints appreciated. It'd be novel to know how fast I'm going. ;-)
Teri
  qt-50 speedoTopic by: Teri Teri 06/08/01 12:33PM
  Re: qt-50 speedoRe: Reeperette Reeperette 06/08/01 06:04PM
  Re: qt-50 speedoRe: Teri Teri 06/10/01 01:38PM
