84 honda spree 2 cycle engine does it have points and condser or electronic ignition ?
84 honda spree 2 cycle does it have points and con
Lectronic... no points and condensor
It has a CDI
I have 85 Spree
No, it does not have points and condensor. It has electronic ignition, located in a box attached to the air filter. Follow the thick black lead back from the spark plug wire into the box (described above).
If its not running right it is unlikely an elect. ign problem......more likely, bad plug, blocked or restricted air filter, gummed up carb or old or gummed up fuel strainer, tank or similar.
Cheers
