Re: searching for a bit more speed ...
don-ohio /
Hi,to ` No One' in particular! Pun intended. Well,I can't speak for all air boxes,just three that I've modified on my own bikes,and the plugs are actually not plugs but tubes which can be popped out and that leaves a much bigger hole.You can pop them right back into place if need be,but I haven't had to do that yet.Sorry if I confused you when I mistakenly said `plug' when I should have said something else.I just never make a modification that I can't reverse unless I'm awful sure it's gonna' be a permanent one.BYE!
