Re: searching for a bit more speed ...
don-ohio /
Hi,Miguel! I don't know if you saw my post a while back,but my minnarelli was starving for air.Make sure you're getting enough,because I gained 4mph and after I drill another hole in the air box I think I'll be approaching 38 mph! But don't do anything to your airbox that you can't reverse.In order to test for problems,I pulled the inserts(2 of them in mine)and when I saw an improvement,I drilled an extra hole.BYE!
