Re: Rust in tank
Henry Moreira /
": I've got rust inside my gas tank that just won't quit. 2-3 times a week I end up disconnecting the gas line and draining off some more rust and paint. Does anyone know of something I can put in there to seal it? Thanks. <p>I've had the same problem. There's a kit you can purchase, it comes in two or three bottles. The one I got came in two bottles. The first one was a deruster, careful with it because it's acid. The second is a neutralizer and a sealer. The process takes between 1-4 hours depending on how rusty the tank is. It is a plus if you can remove the tank, my tank is removable, but with one thats built in it's a little more tricky because the acid can ruin the paint job. If you don't want the hassel you can always send to the shop."
  Rust in tankTopic by: Outlaw Outlaw 08/08/99 03:14PM
  Re: Rust in tankRe: Henry Moreira Henry Moreira 08/08/99 10:03PM
  Re: Rust in tankRe: terry doerr terry doerr 08/10/99 05:40PM
  Re: Rust in tankRe: Henry Moreira Henry Moreira 08/10/99 10:40PM
  Re: Rust in tankRe: dan dan 08/10/99 01:56PM
