My plug looks sort of dry... I added a biturbo to my 2000 Targa.
It's oil injected-- I think I should increase the flow a little.
Thanks for advice!
Thanks for advice!
I don't know about your injector, but if all else fails, you can always add a bit of oil to the gas tank.
Chris.
Did they give you a bigger main jet for the carb with the pipe?
If the plug color on a plug chop is going whitish... you prob need the richer main.
More oil will help.. but it won't "fix" a too lean air/fuel condition... which can cause a piston seizure.
No, They said that the 2000 tomas had a decent size jet to begin with.
But, I told them I didn't want to mess with the carb-- maybe they just wanted to make the sale
