Its probably a problem with the ratchet inside the kickstarter, that is not springing back as it should. Try oiling the ratchet (the bit that clicks with the kick starter returns) or even replacing the spring. Sometimes just shaking/knocking the moped a bit will help to return the ratchet. Tell me if my theory works! It may be limited to certain models.
