How To Replace the Bearing in Vespa Wheel Bracket
From Moped Wiki
(Redirected from Vespa Wheel Bracket)
Jump to: navigation, search
If your Vespa wheel bracket bearing has gone bad, never fear! Buy yourself a nice 6202z bearing, and ten minutes after it arrives, you'll be reinstalling your bracket on your bike.
Here's your bracket. See those two crazy bumps? They're really soft aluminum rivets.
Grind them off! Or drill them out. I ground them off. Easy. Ten seconds.
Plate off! No biggie. Small screwdriver and pry. Easy.
Now slip that small screwdriver in this side and start twisting to pry that baby out. Work it around a little at a time. Mine just came out. Some people heat up the bracket. I didn't need to. After I ran out of twisting leverage with the small screwdriver, I switched to a big one.
Next, pop the remainder of the rivet out of the hole. I used a nail set. Doesn't take much. Oh, and my anvil is an old brake rotor. Works great! Almost done!
As with any other bearing, grab a socket of appropriate size to match the outer race, and tap it in place. Remember, it came out easy, so it should go in easy. If not, you're doing it wrong! Anyway, get it in and ensure it is seated. No excessive force needed.
To finish off, I just used a couple of pop rivets. Cake! Done! Congratulations!
