Moped Wiki
Vespa Ciao
From MopedWiki
Jump to: navigation, search
Contents
Piaggio's introduction to mopeds begin in 1967 with the "Ciao." The company added the model to its line-up as an economy vehicle targeted at a younger audience. The Ciao's production ended in 2006, sadly.
Specifications
1978 Ciao Deluxe
Enlarge
1978 Ciao Deluxe
  • 49.9cc displacement
  • 10mm Dellorto SHA Carburetor
  • 17" x 2" spoked rim size
  • 16" x 2" magnesium alloy (mag) rim size
  • Internal rear wheel Transmission
  • 6v electrical system
  • Variable suspension (see "Models")
  • Belt drive
Models
Base Model
The base model Ciao featured a rigid front and rear suspension.
Ciao Deluxe
This model featured front suspension by a set of springs that allowed the front wheel to pivot forward. Rear suspension was handled by a large spring mounted at the bottom of the seat post, allowing the saddle seat to flex into the frame. This proves for quite a fun and bouncy ride.
Ciao Deluxe with Turn signals
Same as the Ciao Supreme - but with an added turn signal system. Metal boxes were added to the sides of the rear rack to house the 6v battery system for the signals. The front signals mounted to posts fixed to the handlebars, and rear signals were mounted by a small bracket sandwiched between the frame and the rear fender.
Visual Differences
American Ciao's manufactured pre-1978 are noticeable by the emblem on the side of the tank with the "Ciao" logo. The Vespa logo generally appeared as a sticker on the rear of the sidecovers.
American models post '78 sported "Vespa/Piaggio" down the tank, and the Ciao typeface was located on the plastic sidecovers.
In 1974 they changed from a circular taillight to a more squared off style, similar to the CEV lenses found on the Vespa scooters at the time.
Parts and Performance Parts
A large number of performance parts exist for the Ciao. Found mostly overseas, there are numerous performance exhaust pipes, carburetors, cylinder kits, and body modification parts available to purchase.
Performance Tuning
The most basic/common upgrade is a light performance exhaust, such as the Sito+, and either a Dellorto SHA 12/12 carburetor with a Grande airbox.
You can get a little more speed from a 13/13 carburetor and drilling out holes in the airbox, or purchasing a performance airbox such as the Malossi RedFilter, though this procedure ends in a noisier bike.
Further tuning with performance cylinders, porting, and higher end exhaust pipes will result in a very fast little bike.
External Links
Information
Manual and Repair
Parts Resources
Media
Toolbox
