Troubleshooting guide
From MopedWiki
Here is a typed-out version of a troubleshooting guide from a moped manual. Fred's Guide is also an excellent resource for troubleshooting moped problems and explaining how to fix them.
Engine Does Not Start / Running Engine Stops
Version One
The problem is listed with the solution in parentheses.
- Fuel valve is closed. (Open [petcock]] or switch fuel valve to "reserve.")
- Fuel tank is empty. (Switch fuel valve to "reserve" or fill with fuel mixture.)
- Spark plug is contaminated. (Clean spark plug.)
- Spark plug is defective. (Replace spark plug.)
- Ignition cable has worked loose or come off. (Properly plug spark connector.)
- Too much or too little gas. (Open throttle about 1/3.)
- Vehicle put out of operation with fuel valve open. (Start with throttle wide open.)
- Choke operated with warm engine. (Remedy as above.)
- Petcock is clogged. (Have it cleaned by a workshop.)
- Main jet is clogged. (Clean main jet.)
- Float needle not fixed in its notch. (Remove float needle and engage it.)
Version Two
The engine will not start because...
There is no ignition spark because
- Spark plug is oiled, wet, or damaged.
- Spark plug is wet (outside).
- Ignition cable is loose or broken.
- Short-circuit switch jams or leads from engine are damaged.
- Contact breaker points are oiled up, wet, or fused.
- Ignition armature or condenser is damaged.
Engine is getting no fuel because
- No fuel in tank.
- Fuel valve/petcock closed.
- Strainer in the fuel valve/petcock clogged with dirt.
- Fuel line/hose jammed.
- Jets clogged.
There is no ignitable mixture because
- Fuel/air mixture too rich due to excessive priming.
- Water in carburetor.
- Wrong fuel/air mixture due to loose carburetor.
Lack of compression because
- Piston rings broken.
- Piston and cylinder excessively worn.
- Cylinder head or spark plug loose.
- Decompression Valve dirty or stuck.
Engine Runs Unevenly or Misfires
The problem is listed with the solution is in parentheses.
- There is not enough fuel in the tank. (Open fuel valve to "reserve" and fill with gasoline mixture.)
- Float leaks. (Replace float.)
- Ignition cable is not properly connected. (Properly plug spark connector.)
- Jet needle is loose. (Clamp needle in its notch.)
Engine Power Drops / Poor Performance
Version One
- Choke is working all the time. (Push back choke – full throttle.)
- Exhaust pipe is clogged. (Cleaning the muffler.)
- Exhaust port is clogged. (Clean exhaust port.)
- Float leaks, float needle deformed/jams. (Check all parts of the float chamber and replace if necessary.)
- Float needle is loose. (Clamp needle in its notch.)
- Air filter is clogged. (Clean air filter.)
- Spark plug gap is set incorrectly. (Gap spark plug correctly.)
Version Two
Engine power drops...
Due to dirt because
- Air filter clogged.
- Exhaust port and transfer ports in cylinder clogged with carbon.
- Thick carbon deposits in cylinder head.
- Exhaust pipe and muffler are dirty.
- Vent on fuel tank cap clogged.
- Spark plug vitrified.
Due to reduced compression because
See "Lack of compression" under Engine does not start
Other Engine Troubles
Irregular running because
- Ignition cables loose or damaged.
- Engine gets too hot, causing fuel vapor bubbles to interrupt fuel supply.
- Contact breaker points oiled or burnt.
- Supporting pin for contact breaker arm worn.
- Spark plug or connector or ignition armature defective.
Engine four-strokes and does not accelerate because
- Carburetor flooded due to dirty or worn needle.
- Float is leaking.
- Exhaust port is clogged with carbon.
- Carburetor not correctly adjusted or jet loose.
- Air filter dirty.
Engine knocks while running at full throttle under load because
- Too much engine advance.
- Excessive carbon deposit in the combustion chamber.
- Cooling fins dirty.
Engine backfires or spits into carburetor because
- Engine does not get sufficient fuel.
- Spark plug glowing due to wrong heat value.
- Spark plug bridged, dirty, or vitrified.
- Engine getting wrong fuel/air mixture.
- Glow ignitions.
Engine does not idle because
- Idle screw incorrectly set.
- Control cable for throttle valve incorrectly set.
- Ignition armature damaged.
Engine consumes too much fuel because
- Gas tank, fuel valve/petcock, or carburetor leaking.
- Jet needle or needle jet too worn.
- Jets too large.
Engine does not accelerate smoothly because
- Low engine power (see above somewhere).
- Clutch plates worn.
- Clutch plates glazed due to overheating by two people riding moped, too high idle speed, insufficient or wrong type of Transmission fluid used.
