Moped Wiki
Tomos Sprint
From MopedWiki
Jump to: navigation, search
The Tomos Sprint is the entry level model from the classic line. It is the cheapest Tomos model available and also the lightest. The Sprint is similar to the ST/Targa model but lacks oil injection, turn signals, and has a smaller headlight fairing. Post-2007 models are equipped with the A55 engine, cast aluminum forks, new seat design, and a catalytic exhaust. The Tomos Sprint is currently only available in black.
1992-2006 Model Technical Specifications
  • A35 Engine
  • 49cc two stroke
  • 38mm X 43mm Bore/Stroke
  • 9.1:1 compression ratio
  • Automatic 2 speed transmission
  • Dellorto SHA 14/12 Carburetor (#53 jet stock)
Maintenance Information
  • Gearbox oil: Type A or Type F Automatic transmission fluid.
  • Spark plug: NGK B6HS, Bosch W4A2, Champion L82
  • Spark plug gap: 0.5mm
  • Timing advance: 1.5-0.2mm BTDC
  • Points Gap: 0.35-0.45 mm (Points ignition models only)
Toolbox
