Talk:Float bowl
From Moped Wiki
Jump to: navigation, search
I don't know what I'm doing I guess. I can't figure out why Float Bowl and float bowl pages don't see each other naturally without a redirect. I thought it was capitalization, but I don't even know if that matters.
Many other carburetor parts links have the same problem.
Dean Says!
I think it has to do with the "Bowl" in "Float Bowl" being capitalized in one, but not the other.. though I could be wrong. I think the first letter can be either way, but other letters in the word cannot. Worth a try, I guess?
Brendan Replies!
Well, I 'moved' Float Needle to float needle and it automatically redirected so I guess it is no longer a problem. Problem solved.
Simon chimes in!
Yep, the first letter doesn't matter but every other one does. It's normal to make a redirect from the other capitalization and moving it is a good way to do that. Normally lowercase is preferred and upper case should be redirect to it -- unless it's an proper name or acronym or something like that.
