Moped Wiki
Solo Belt Adjustment
From MopedWiki
Jump to: navigation, search
INCOMPLETE IN PROGRESS
Description
The Solo moped drive system consists of a clutch connected to a pulley via a v-belt. On the back of the pulley is a sprocket. The sprocket is connected to the rear wheel via a light duty motorcycle chain. If your belt becomes worn it may slip. These instructions explain how to adjust it.
Tools Required
  • Socket wrench (two can be useful)
  • 13mm socket for each wrench)
  • Short extension
  • 13mm combination open/closed wrench.
Instructions pending.
This article is a stub.
You can help the Moped Wiki by expanding it.
Toolbox
