Puch cylinder kit summary
From Moped Wiki
(Redirected from Puch kits)
Jump to: navigation, search
This is a summary of all known Puch (Maxi) cylinders. This information is as-is and not guaranteed to be correct.
Puch 50cc Stock old model (38mm)
Stock Puch cylinder with open ports.
Distinguishing marks:
  • Small, unconnected cooling fins
  • Open ports
  • Rectangular intake
Pros:
+ Reliable
+ Wear-proof
Cons:
- Discontinued
Description:
  • Aluminum with chromed wall
  • Intake port: oval
  • Ports: 2
  • Exhaust port: oval
Special points of interest:
  • Open ports.
  • 16mm carb fits without modifying.
  • Revs higher than the closed ports version.
  • Less torque than the closed ports version.
Puch 50cc Stock new model (38mm)
Stock Puch cylinder with closed ports.
  • Bigger, connected cooling fins
  • Round intake
Pros:
+ Reliable
Cons:
- Discontinued
Description:
  • Cast-iron
  • Intake port: oval
  • Ports: 2
  • More torque than open ports version.
  • Revs less high than open ports version.
Airsal 50cc (as stock) (38mm)
Replacement cylinder for stock Puch cylinders. Has closed ports.
  • Bigger cooling fins than stock cylinders with open ports.
  • In contrary to the fast 50cc Airsal, no logo.
Pros:
+ Reliable
+ Cheap
Cons:
- Rattles somewhat
- Poorly finished
Description:
  • Aluminum with nicasil wall
  • Intake port: oval
  • Ports: 2
  • Finishing the edges of the ports is recommended.
Zeta 50cc (fast) (38mm)
Pros:
+ Accelerates faster than stock Puch cylinders
+ Has a higher top speed than stock Puch cylinders
+/- Powerband comes higher than stock Puch cylinders
+ 7 Ports
Cons:
- Less bottom end power
Description:
  • Cast-iron
  • Intake port: oval
  • Ports (128º): 2
  • Exhaust port (159º): oval
  • Blowdown: 15.5
  • Nice cylinder to replace stock Puch cylinder.
Airsal 50cc (fast) (38mm)
Many say: Best fast 50cc.
  • Round logo on upper-left cooling fin
  • Cooling fins like the closed ports Puch cylinder, but not connected to each-other.
Pros:
+ Reliable
Cons:
- Sometimes poorly finished
- 4 ports
Description:
  • Good timing and most of the times the finish on the ports is good.
50cc TCCD / RGD (fast) (38mm)
Very fast 50cc.
Pros:
+ Fast
+ 6 ports
Cons:
- Poor piston
Description:
  • Intake port: oval
  • Ports (114º): 4
  • Exhaust port (164º): oval
  • Blowdown: 25
Metrakit 50cc (38mm)
Fast 50cc.
  • Big black cooling fins with unique shape
  • Cast-iron
Pros:
+ Fast
Cons:
- Expensive
Description:
  • Intake port: oval
  • Ports (?º): 4
  • Exhaust port (?º): oval
  • Blowdown: ?
  • Big intake that can handle an 18mm carb
Eurocilindro/Athena AJH 50cc (38mm)
VERY fast 50cc reed-valve kit
  • Big reed-valve intake
Pros:
+ Wear-proof
+ VERY fast
+ Reed-valve intake
+ Fits a big carb
Cons:
- Pistons are hard to get
- The valves has tendency to break, change to carbon valves asap.
Description:
  • Aluminum with chrome wall
  • Intake port (variable): Raised intake as booster-port
  • Ports (121º): 4 main ports + 1 booster-port (114º)
  • Exhaust port (175º): oval
  • Blowdown: 27
  • Click to view port map.
  • Reed-valve intake
  • Pulls hard and has high top speed.
  • Reaches 12,000 RPM unmodified.
Parmakit 50cc
Pros:
+ Largest transfers of any 50cc kit
+ Lots of torque
+ Reliable
Cons:
- Discontinued ( supposedly, there are a few out there still )
Description:
  • The front of the exhaust port is 32mm from the top of the cylinder 14.5mm x 27mm wide
  • The back of the intake port is 20mm from the back of the cylinder skirt 13mm x 25mm wide
  • Boost port in front of that is spaced 2mm forward of the intake port and is 18mm x 14m wide
  • All the side ports are 11mm x 13mm wide
Autisa 60cc (42mm)
Description:
  • Intake port (110º): Oval with half bar in the top
  • Ports (128º): 2
  • Exhaust port (158º): oval
  • Blowdown: 15
  • Pretty rare cylinder
  • Half bar in the intake.
Malossi 60cc (42mm)
Pros:
+ Pretty quick for a 60cc
Cons:
- Exhaust port is hard to modify
Description:
  • Intake port (122º): oval
  • Ports (110º): 2
  • Blowdown: 24,5
  • Boost ports (90º): 2
  • Diameter exhaust port: 25mm
  • Piston-ring-gap goes between the exhaust port & intake port.
  • Piston also works in 60cc 42mm Eurocilindro kit for Puch.
Stock Hero Puch 65cc (43mm)
Stock cylinder found on Hero "turbo sport"
  • Large cooling fins
  • Unique fin shape
Pros:
+ Rated at 4.5hp off the shelf
+ Massive transfer ports
+ 8 ports
Cons:
- Very poor quality casting
- Ports have very jagged chamfers that need to be cleaned up before cylinder can be run.
Description:
  • Cast-iron
  • Intake port (132º) rectangular
  • Ports (114º): 4
  • Exhaust port (144º): rectangular
  • Blowdown: 21
  • Boost ports (107º) 2
  • Material needs to be added to cases to avoid air leaks.
  • Angled 3 bolt intake and angled exhaust
Metrakit 65cc (43,5mm)
Good torque cylinder. Pulls well at every RPM.
  • Black cooling fins
  • Last cooling fins have a sloped edge
Pros:
+ Very good pull from low RPM
Cons:
- 4 ports
Description:
  • Round intake that is large enough for a 20mm carb.
Airsal 65cc (44 mm)
Nice cylinder with pretty good pull and nice top speed.
  • Round logo on cooling fin
Pros:
+ Cheap
+ Reliable
Cons:
- Poorly finished
- 4 ports
Description:
  • Intake port: oval
  • Ports (114º): 2
  • Blowdown: 25
Polini 65cc (43,5mm)
Fast reed-valve kit. Ideal for high top speed. Read this if you plan to run one... [1]
  • Reed-valve intake
  • Unique intake
Pros:
+ 7 ports
+ Good finish
+ Reed-valve
+ VERY torquy
Cons:
- Expensive as hell
- Pistons are expensive too
- Needs very good carb tuning and oil-mixture
Description:
  • Aluminum with chrome wall (old models)
  • Aluminum with nicasil wall (new models)
  • Transfer ports (114º): 4 ports + 3 boosters
  • Blowdown: 25
  • Reed-valve intake
  • Rivals larger displacement cylinders in power
  • Very seize sensitive. Needs perfect mixture to run well.
Parmakit/Zeta/Autisa 70cc (45mm)
Discontinued
  • Booster port that goes into the intake
Pros:
+ Reliable
+ Wear-proof
Cons:
- Discontinued
- 4 ports
- Intake is hard to modify, the booster port gets in your way
- Foot-gasket thickness comes very close. The booster port in the piston might be in front of the intake, so it doesn't run.
Description:
  • Cast-iron
  • Intake port: Square, U-shape
  • Ports (114º): 4
  • Exhaust port (164º): Oval
  • Blowdown: 25
  • Special boost port.
More info: http://mopedluau.blogspot.com/2014/10/finally-its-autisa-time.html
Airsal 70cc (45mm)
Very nice cylinder. A lot of people say: The perfectly timed cylinder.
Pros:
+ Cheap
+ Reliable
+ Well timed
Cons:
- Rattles
- 4 ports
- Poorly finished
Description:
RGD/TCCD 70cc (45mm)
Almost the same as Airsal 70cc. Some say that the old TCCD was made of better materials than the new RGD.
Pros:
+ Cheap
+ Well timed
+ 6 ports
Description:
  • Intake port (127º): oval
  • Ports (121º): 4
  • Blowdown: 21,5
  • Boost ports (114º): 2
K-Star 70cc (45mm)
Good cylinder with good torque. Can be very fast with modifying.
  • Dark grey cooling fins
  • K-Star logo on cooling fin (Upside down when installed. Morons. :P Fixed on newer kits.)
Pros:
+ Cheap
+ 6 ports
Cons:
- Poorly finished
Description:
  • Good tuning material
  • Good piston & rings
  • Some pistons have their ring gap at 12:00, can cause expansion into windows
  • Guide to making it faster - K-Star 70cc Kit Compendium
  • DMP 70cc kits are almost identical, but they are inconsistently finished (better OR worse) and cast with less quality
Polini 70cc (45mm)
Very fast 70cc cylinder. Sadly discontinued.
  • Special port-shape
Pros:
+ VERY fast
+ 6 ports
Cons:
  • - Discontinued
Description:
  • Intake port: oval
  • Ports (105º): 4
  • Blowdown: 35
  • Boost ports: 2
  • Good quality chrome wall
  • Discontinued
Eurocilindro/Athena 70cc (45mm)
Fast 70cc.
  • Eurocilindro on bottom cooling fin (Only on Eurocilindro, not Athena)
Pros:
+ Wear-proof
+ Good torque
Cons:
- Pretty expensive
Description:
  • Intake port (140º): oval
  • Ports (105º): 4
  • Exhaust port (160º): oval
  • Blowdown: 27.5
  • Better piston than in the reed-valve kit.
Fast 70cc reed-valve kit.
  • Reed-valve intake
  • Unique intake
Pros:
+ Very fast
+ Good torque
+ 6 ports
Cons:
- Wrong piston comes with the kit
- Metal reed-valves break easily. Recommended that you replace them by carbon valves.
Description:
  • Ports (122,75º): 4 ports + 1 wide booster
  • Exhaust port (165º): Oval
  • Blowdown: 21
Eurocilindro/Athena AJH 70cc (45mm)
  • Unique intake
Pros:
+ Wear-proof
+ Fast
+ Reed-valve
+ Intake large enough for a big carb
Cons:
- Piston is very sensitive at the ring-gap. A good replacement is a 70cc Polini piston for Honda MT5/MB5
Description:
  • Intake (variable): Raised intake as booster port
  • Ports (128º): 4 ports + 1 wide raised booster (107º)
  • Exhaust port (165º): oval
  • Blowdown: 18.5
  • Reed-valve intake.
  • Poor piston.
  • Comes with a 2-valve reed-valve, but takes a 4-valve Honda reed-valve with a simple riser & Honda intake.
Airsal 72cc (46mm)
New Airsal cylinder. Biggest displacement you can fit on a Puch without modifying the crank-case.
Pros:
+ Big displacement without modifying crank-case
+ Comes with HC head
+ Massive torque hit in the midrange
+ Crazy high compression good for power if you set the timing back
Cons:
+ Case sometimes needs to be gently dremeled in order to make cylinder sleeve fit.
+ Cylinder sleeve is VERY thin, and can crack over time
+ Aluminum in HC head is very soft, may strip out spark plug threads after only a few months.
+ Piston hits head, requires two head gaskets or two base gaskets similar to metra 65.
Description:
  • Intake port: oval
  • Ports (128º): 4
  • Blowdown: 23.5
  • Round intake that fits a 20mm carb
  • Available with a straight and angled exhaust port
Parmakit 75cc (47mm)
New cylinder with a LOT of tuning-potential
  • Butterfly intake & exhaust port.
Pros:
+ Butterfly intake port
+ Butterfly exhaust port
+ Lots of torque because of the butterfly ports
Cons:
- 4 ports
- Comes without a head
Description:
  • Intake port (132º): Butterfly port
  • Ports (132º): 2
  • Exhaust port (170.5º): Butterfly port
  • Blowdown: 19.25
  • Boost ports: 1
  • Angled exhaust port.
  • Crank-case needs mod-work to fit cylinder.
Eurokit 75cc (47mm)
  • Extra ports in the cylinder wall.
Pros:
+ 8 ports
Cons:
- Discontinued
Description:
  • Intake port: Oval
  • Ports: 4
  • Exhaust port: Oval
  • Boost ports: 2
  • Special boost ports.
Gilardoni 75cc (47mm) (Reed-valve)
Gilardoni Reed size vs. Polini 4 petal
Gila Ports
Gila ports.jpeg Cil64-resize.jpg Cil65-resize.jpg Cil66-resize.jpg Cil67-resize.jpg
  • Reed-valve
  • Square cooling ribs
Pros:
+ Reed-valve
+ Fast 75cc kit
Cons:
- Piston doesn't have the pin in the center
Description:
  • Minarelli Vertical intake fits without modification.
  • Minarelli AM6 (Aprilia, Rieju, newer Derbi's etc.) reed-valve fits without modification.
  • A lot of people say that you have to replace the piston with a Metrakit or Airsal piston, because the original piston isn't suitable for right-turning engines because of the off-center piston-pin.
Metrakit 75cc (47mm)
Pros:
+ Torque cylinder
Description:
  • Cast-iron
  • Intake port (153º): Oval
  • Ports (121º): 4
  • Exhaust port (175º): Oval
  • Blowdown: 27
  • When fitting this cylinder you should mind the piston-rings. They come out of the intake, you need to push them back before sliding the piston further in.
Zeta 75cc (47mm)
Not much known.
Has a bad aluminum with nicasil wall.
Translated by SchijnHeilig
Original from Puchforum.com
Port maps originally posted on Puchforum.com (see the sticky in the tuning section) or Bromsprintforum.
<tr"></tr>
Puch Information
Puch Engine VariationsE50ZA50KoradoE50 (kickstart)Magnum XEngine differences (photos)
Puch PartsAluminum cylindersHigh torque cylindersBing
Puch PerformanceKit summarySpeed/setup tableExhaustsE50 crankshaftsIgnition system summary
