Moped Wiki
Puch ignition summary
From MopedWiki
Jump to: navigation, search
Contents
This is a list of almost every ignition you can fit onto your Puch engine.
This list is sorted by price-range.
Stock Puch Maxi points ignition
The stock Puch Bosch/Iskra ignition.
There are 2 different versions of this ignition:
  • Newer version: Primary coil -> Secondary coil -> Sparkplug
  • Older version: Ignition coil -> Sparkplug
Found on:
Consists of (New model):
  • Baseplate
  • Flywheel
  • Contact-points
  • Condenser
  • Primary coil
  • Secondary coil
  • Light coil
Consists of (Old model):
  • Baseplate
  • Flywheel
  • Contact-points
  • Condenser
  • Ignition coil
  • Light coil
+ Cheap
+ Reliable (if maintained well)
+ Easy to tune
+ Easy to install
+ Good light coil (6v 17W)
- Contact-points (Sometimes not very reliable)
- Moisture sensitive
- Doesn't work well above 12.000 RPM
- Heavy flywheel (Bad throttle response)
Special points of interest:
  • There are cheap imitation coils, contact-points and condensers available.
  • Original Bosch parts are also available. Original Bosch is preferred over imitation, especially with contact-points and condensers.
Puch Z-one CDI Ignition
The original Ducati CDI ignition for Puch Z-one.
Consists of:
  • Baseplate
  • Flywheel
  • Primary coil
  • Secondary coil
  • CDI
  • Light coil
+ CDI ignition (No contact-points)
+ Works well above 12.000 RPM
+ Very good light coil (12v 35W)
- Doesn't seem to last very long
- Hard to tune
- Heavy flywheel (Poor throttle response)
  • Was only stock on Puch Z-one
Sparcon Contact-points Replacement
A sort of module that attaches to the baseplate to replace condenser and contact-points.
+ No contact-points
+ Works above 12.000 RPM
- Not tuneable
  • One of a kind. Doesn't work with every engine the way it should.
  • Price is around $20 which is a lot for a device that doesn't work with every setup.
HPI CDI Inner-rotor
Image:Ign2.jpg Image:Ign3.jpg
HPI 2005
Horse Power Ignition inner-rotor with "curve"*
Consists of:
  • Rotor
  • Stator
  • Coil
  • CDI
  • Light coil (optional)
+ Works up to 18.000 RPM
+ Is moisture resistant
+ CDI ignition
+ Easy to install
+ Light flywheel (Better throttle response)
+ Curve
- Expensive
- No lights (There is a light coil available, but it delivers just 12v 10W. Barely enough to run lights)
- Hard to tune precise
- Parts that can break are expensive
  • Only ignition with curve for Puch.
    • Curve means that it has a programmed CDI that delays the ignition when the RPM rises. This ensures that you have good low-end and high-end power.
Selletra analog CDI inner-rotor
Consists of:
  • Stator
  • Rotor
  • Coil
  • CDI
  • Baseplate
+ Is moisture resistant (Plastic plated stator, coil & CDI)
+ CDI
+ Quality, finish and fit
- Not meant for Puch (It's meant for Piaggio & Minarelli. It does fit Puch)
- Expensive
- No light coil
- No curve* (Analog, does not delay the ignition timing)
- Hard to tune
  • Not meant for Puch, but for scooters.
Brands:
  • Italkit Selletra
  • Malossi Selletra
  • TNT Selletra
They are basically all the same.
  • Only Malossi has an Eprom. That's a self-programmable CDI so you can make your own curve. It is expensive however.
There's also a digital Italkit Selettra with curve, but it's a lot more expensive than the HPI.
MotoPlat Electronic Outer-rotor
Image:Ign4.jpg Image:Ign5.jpg Consists of:
  • Rotor
  • Stator
  • External coil
  • Light coils
+ No contact-points
+ 2 light coils
- Heavy rotor
- 40 year old design
- Discontinued
  • MotoPlat has only made this ignition for a couple of years. The factory is long gone (Bankrupt).
  • It out-performs the stock Puch ignition, however the flywheel is kind of heavy.
  • This ignition doesn't have contact-points or CDI, but works with an external coil & 2 light coils.
Translated by SchijnHeilig
Original by Jorismb from Puchforum.com
Special thanks to 'puch rijder martijn' and Jos Dijkman for the information on the MotoPlat ignition.
Toolbox
