Puch bearings
From MopedWiki
A list of bearings and seals needed to rebuild a Puch E50 engine, divided by crank. (See Puch E50 Crankshafts for more information on the different crankshafts).
Stock, DMP Stuffed/Unstuffed, Super Stuffy, Rito
The complete list of Puch E50 bearings and seals for the stock crank, the DMP stuffed/unstuffed crank, the Treats Super Stuffy crank, and the Rito crank is:
Bearings
- 3 X 6203 C3 (two counter shaft bearings optional)
- 1 X 6203 NR
Seals
- two 2 X 17x40x7 Double lipped
- one 1 X 22x40x7 Double lipped
Top Racing
Bearings and seals needed for the The Top Racing Crank:
Bearings
- 1 X 6203 ST 17x22x12 (outer race) 11mm inner race -Clutch side snap ring
(-or a 6203 NR with the clutch side circlip slot machined 1mm further)
- 3 X 6203 C3
Seals
- three 17x40x7 seals (and zero 22x40x7 seals)
Where To Buy
Allied Bearings Corporation
3525 W Lincoln Ave
Milwaukee, WI 53215
(414) 672-3111
http://www.alliedbearingcorp.com/
Crush Bearings & Drives Inc.
325 Baxter Avenue
Louisville, KY 40204
Ph: 502-589-3239
Ph: 800-573-2359
Fax: 502-568-6590
http://www.crushbearings.com/
Action Bearing Company
201 Brighton Avenue
Allston, MA 02134
Ph: 617-782-1400
http://www.actionbearing.com/
