Puch Korado
From MopedWiki
The Puch Korado was a moped designed by Piaggio and released in 1995. (The Puch name was purchased by Piaggio in the 1990's.) The Korado engine was a modernized and improved version of a normal E50, and it came in both regular (pedal) and kickstart versions. The kickstart version was second design of a kickstart E50 engine used by Puch. (The first kickstart E50 was used on the Magnum X. These engines are highly sought after.
Korado Engine
The engine was made by the Povazske Strojarne company under the Puch name. This engine was very different from previous E50's. Some differences are as follows:
Bottom End
- back-cut internal gearing resulting in a clockwise rotating stator (opposite of all previous E50's), but with the same internal gear ratio
- much larger stock transfer ports and a rollerbearing crank.
- either three or four main bearings as compared to almost all other E50's (other then some after 1985) having four.
Electrical
The Korado had a few variations of its electrical system as well. Variations include:
Top End
Differences in the top end included:
- an aluminum cylinder and head with a very well made squish band
- four transfer ports and a stock boost port
- a single dykes ring piston
- a slightly angled exhaust port and a stock 14mm Bing carb and intake
There were changes with the clutch assembly as well which included a stock three shoe clutch and an extremely lightened/better flowing clutch bell. The whole kick start mechanism remained unchanged however.
Photos
Please click on an image if you would like to see a larger version.
| Puch Engine Variations |
| E50 • ZA50 Puch Korado → E50 (kickstart) ← Puch Magnum X |
