Peugeot moped models
From MopedWiki
(Redirected from Peugeot Moped)
Jump to: navigation, search
Contents
Model Classification
Models
    • 101 - Not sold in America Non-variated, piston port, rear swing arm starts behind the pulley. Detachable gas tank (same tank as 104)
    • 102 - Non-variated, piston port, rear swing arm starts behind the pulley.
    • 103 - Variated, Case-inducted reed valve, Swing arm runs entire length of frame (does not torque drive chain). there is a rigid model 103 that was sold in the Chicago area with a cylinder inducted reed intake, but with a single-speed clutch.
    • 104 - not sold in America Same engine and swing arm as 103, but with detachable gas tank, long rear rack, and long seat.
Classification
    • SP - Sport model. Higher forks and shocks, chrome wound rear shocks, chrome fender in back, chrome rear rack.
    • LVS - Standard model, painted rear fender that covers part of rear wheel, chrome plated covered rear shock. Lower front forks and rear shocks.
    • LS - Non-variated clutch, engine still variates via the same spring as the LVS
Speed Classification
Generally 5mph shy of actual top speed. The U3 model is a 38-40mph bike
    • U1 - 20MPH
    • U2 - 25MPH
    • U3 - 30MPH
Speed restricted by carb/intake size, so upgrades can be made.
the VIN tag behind your headlight might say something like 103LVS U3, or 102SP U2
Red Arrow   Swarming and Destroying since 1997   |   Contact Us   |   Back to the top
