Performance racing CDI
From Moped Wiki
Jump to: navigation, search
This is in hopes of clearing up some of the confusion related to the "blue box" racing CDI's.
There are numerous versions of this, some with lights. The box is typically an anodized blue with a sticker indicating some sort of curve. Amusingly the curve has no units nor meaning and the box does not have any sort of timing curve built in. Also interesting is the advertising of either a "2 stroke" or "4 stroke" version. This would imply a timing curve (advancing for 4t, or retarding for 2t, but both appear on all accounts to be identical and without timing curve.
4 or 5 pin
The 5 pin wired version should have a connector which matches the 5 pin CDI pinout shown above.
__[]__
[1-2-3]
[4-5-6]
  • 1 - timing input - Blue wire
  • 2 - empty
  • 3 - is power out to the HT ignition coil - Yellow wire
  • 4 - ground - Green wire
  • 5 - kill switch (grounds to kill engine) - Black wire
  • 6 - power input from the stator - Red Wire
Or if you're just running it off the wires:
  • yellow (from the CDI box) - Out to HT coil
  • blue from box - Timing impulse in
  • red from box - Power in from stator
  • black from box - kill switch (ground to kill engine)
  • green on box - ground
6 pin
Some come with the 6 pin connector like that shown above
The wires here should be as follows:
[1-2][3]
[4-5][6]
  • 1 - Timing pulse in
  • 2 - Out to HT Coil
  • 3 - Kill Switch
  • 4,5 - Ground (either or both)
  • 6 - Power in from stator
And the wires without the plug:
  • yellow - Out to HT coil
  • blue - Timing impulse in
  • red - Power in from stator
  • black - kill switch (ground to kill engine)
  • green - ground
