Performance Tuning a Suzuki
From MopedWiki
Performance Tuning a Suzuki FA50 or FZ50.
Contents |
FAQs
Q-How fast should my Suzuki go?
- A-Stock the FA50 should reach 28-30mph. Stock the FZ50 should reach 30-34mph A correctly adjusted carburetor and Muffler cleaning are the two most important factors in reaching the stock speeds.
Q-Why won't my Suzuki start or idle well?
- A-Common problems are idle speed and mixture adjustments, clogged idle jet, and rusted fuel bowl floats.
Q-How do I make my Suzuki faster?
- A-It's important to start with a bike that at reaches the stock speeds. If you can't reach near these speeds something is wrong and all future adjustments will be off. Tuning a FA50 to hit 28 mph is cheaper, easier than tuning to break 32 mph. Start with Fred's Guide.
Increasing power, and top end performance.
One of the fastest and virtually free improvements is increasing compression by milling or shaving down the head. Raising compression boosts power across all ranges. The original motors had low 6.5:1 compression. It's possible to remove at least 1 millimeters from the head, bringing the mating surface even with the cooling fins, and remove the head gasket while still using 87 octane without issue. Compare head gasket diameter to combustion chamber diameter for a gauge of piston clearances.
Air Filter
The stock air filter is restrictive. It is possible to drill a few holes to increase airflow. Other easy options for the FA50 include removing the plastic airbox and reusing the rubber elbow connecting it to the carb. Various "performance" auto parts store valve cover breathers will fit this elbow. The FZ50 air filter bolts on to the carb with 2 screws. New filter housing can be either screwed to bracket or a rubber hose can be fitted to the carb throat to adapt other filters. If a bike bogs with a less restrictive air filter it could be the sign of a clogged idle jet.
Exhaust
One of the few performance parts available for the 49cc Suzuki motor was the Simonini Expansion chamber. Powerband is a little high, it kicks in at about 22mph. There is some loss of low end power but worth the major increase in top end power. The Simonini pipe has been out of production for awhile and can be hard to find. The next solution is to cut the muffler off the exhaust header and weld an expansion chamber from a different bike in its place. You should try to match engine size and power band from the donor bike. Expect to increase your carburetor jetting to prevent a lean condition and to maximize top end power. The lost low end can be regained by increasing the compression if not already done.
Tires
FA50 tire size is restricted by the minimal clearance to the rear mounted carburetor. Low tire pressure can add significant drag, up to a 5 mph loss. Inflate to 35 psi or higher for less resistance. FZ50 rear tire size can be increased from a 12x3" tire to 12x4" with minimal changes. This adds about 2" in tire height which will increase gearing and top end. A 12x3.5" tire should fit with out any changes. The 12x4" requires filing a bump off the transmission and off setting the 2 wheel pieces by 1/4" with washers.
http://www.mopedarmy.com/wiki/Image:Tires.jpg
Transmission
The FA50 service manual recommends running 500ml 20w-40 multi-weight oil. Changing to Mobil 10w-30 synthetic is worth a 2-4mph increase. Another common problem is an overfilled transmission. More than 500ml will add excessive drag on the drivetrain. Its only necessary to fill the transmission 300ml.
The FZ50 has a 2 speed automatic transmission. The 2nd speed clutch works by centrifugal force dictated by rpm. Typically they shift between 10-12 mph. The service manual recommends 900ml of 10w-40. The most common ways to raise the shift point on similar clutches are running thicker oil, lightening the clutch shoes, flipping the clutch shoes or changing to stronger springs. No particular oil weight seems to affect the shift point. The 10w-30 synthetic does cause a longer shift into 2nd, which could help acceleration, but shows excessive wear and particles in the oil. Oil designated for motorcycles and wet clutches will give greater protection for clutches and transmissions. Lightening the clutch shoes will cause 2nd to shift later, but it slips until it fully engages causing extra wear.
http://www.mopedarmy.com/wiki/Image:Fz50_14mph_shift.jpg
http://www.mopedarmy.com/wiki/Image:Fz50_16mph_shift.jpg
One may also replace the transmission springs with with an after market performance equivalent. In the case of the FA50 and FZ50 first gear clutch, measuring 29mm, Malossi clutch pring set 29 8747. You get 9 springs, 3 sets of 3, but you only need 2 for our purposes. Red are the least strong, blue is next, then black is the stiffest. Red is what you want for your ported & tuned stock set up or mild kit. Blue is for your wild kit, black if you're running a nitrous system.
To read the full tutorial with hi-res photos, visit: http://ob1repairs.blogspot.com/2012/03/suzuki-fz50-clutch-spring-upgrade.html
Engine Kits
An engine kit is generally a an oversized piston and cylinder designed to increase engine displacement. There are a few engine kits available. The most common increases the piston bore from 40mm to 45mm yielding 58cc displacement.
The easiest kit to get in the US is a Suzuki 60cc 77 kit.
http://www.1977mopeds.com/product/50407
NC-Motorsports out of Denmark sells a 45mm kit for Suzuki FZ50/FY50/FS50 as ebay item#250556009383 currently less than $120 with free shipping.
A different kit, untested, 47mm 64cc, $224 plus shipping.
http://www.spi-parts.com/models-1/suzuki/fz50-rascal/polini-kit-suzuki-address-sepia-d-47.html
Another 45mm kit, carbon fiber reeds, 16mm carburetors etc. 8.5 HP!!!
http://www.protunahandels.de/products.asp?c=310842377&n=19065927
More dutch Suzuki performance parts.
http://www.mopedspeed.dk/web-shop/suzuki/fz50/
Increasing engine size will increase low and mid range power but probably won't increase your top end speed without porting. This is because the biggest limit on stock motors it the amount of air available to flow through the engine. Increasing engine size with the same airflow restrictions should actually lower total available rpms.
Porting
Once properly tuned the biggest restriction on top end and speed becomes airflow. Porting the transitions between the carburetor through the entire motor can significantly increase rpm and top speed. On the FZ50 the transition between the intake and the reed block has a 3mm difference between the two. Removing the intake and reed block is only 4 bolts more than removing the carburetor. Using a file or a dremel tool to match these parts will help the engine's powerband and raise max rpm. It is possible to change how the motor breathes by porting the cylinder's windows. Smitty's_Cylinder_Porting_Guide. The Suzuki 50cc intake port is small and could be improved by enlarging and squaring. Stock cylinder port windows extend 2.6mm below BDC. Adding extra base gaskets adjust piston port timing and raises the ports, sometimes referred to as a rev plate. A total of 4 case gaskets will expose all of the ports at bdc, adding about 20-30% to your port size. On a mildly port polished and matched motor this can bring top end and rpms up to reach 40 MPH. This does require at least milling the head as much as you shim to maintain stock compression, and to properly do this the cylinder jug should be decked to retain proper squish band. Keep in mind as top end power and rpm increase low end suffers.
Oil Injection
Both motors use oil injection. The suzuki oil injection is quite reliable. The injection mixes with the ratio of 40:1. The FA50's oil injection tends to cover the spark plug making it difficult to read plug chops. Bypassing the oil pump and switching to 50:1 premix can increase the amount of gas entering the engine.
Spark plug
Performing a plug chop can be a very important guide for adjusting carb jetting.
Fa50 and FZ50 standard plug is a NGK BP4HA, crosses with Nippon Denso W14FP-UL. Its recommended to run a cooler plug especially if raising the compression. Cooler plugs would be the NGK BP5HA and BP6HA.
How to Index a spark plug. Mark the location of the electrode on the spark plug's porcelain. When installing make sure the electrode is opposite the exhaust port. In other words not in the way of the ignited fuel and the exhaust port.
Reference Material
https://docs.google.com/spreadsheet/ccc?key=0AruFlQMph4SPcF9Zc2FobDFCNzlXSE1VQmJ2Q3pOZmc#gid=259
Suzuki 2 stroke (motorcycle) maintenance bulletins
