Muffler belt
From MopedWiki
[edit]
Fictional Parts
A muffler belt is a fictional moped part. If you are asked to check your muffler belt someone is trying to play a joke on you, probably because you are asking a question in which they feel you haven't adequately looked for the answer. In the Moped Army forums, for example, the due diligence required before asking a question is to search for a related existing thread. Ironically, if you've been advised to check the muffler belt, it is very unlikely that you will ever read this wiki page.
[edit]
Other "joke" parts
- Pyramid Power Crystal
- Blinker Fluid
- Blinker Fluid Modulator
- Flux Capacitor
- Muffler Bearings
- Piston Return Spring
- Brass Magnet
- Photon Jiggler
- Intake Jogger
- Seat Battery
- Horn injector
- Brass Balls
- 710 Cap
- Elbow Greese
- Clutch Belt
- Spark Plug Wire cleaner
- Cross Drilled Brake lines
- Adjustable Powerband
- Boost Bar
- Engine Oil Bypass kit
- O-Pipe
- Heavy Duty Tire Beads
- Wiper Blade Sharpner
