Motobecane wheels
From MopedWiki
Just a start, add what you know and have found out!
[edit]
Motobecane 6 star mag wheels
- Sealed bearings front and rear, others floating ball and cone front, sealed rear
- 1.35x17
- 10mm thru axles
- Center hubs removable with 6 hex bolts
- Standard Lelu sized brake pads
- Replacement sealed bearing numbers (1 of each per wheel, assuming both are sealed):
- 6000 (10x26x8)
- 6200 (10x30x9)
Removing the hubs from the 6 Star Mag Wheels
[edit]
