Moped Wiki
Transmission
From MopedWiki
(Redirected from Manual shift)
Jump to: navigation, search
A transmission or gearbox is the gear system that transmits mechanical power from the engine on your moped to the rear wheel.
Types of Transmissions
Depending on the type, some transmissions can have multiple gear ratios. Multiple geared transmissions are typically automatic, meaning the transmission will shift on its own. While rare in the United States, a manual shift transmission can be found on some mopeds.
Included in the transmission on some mopeds is a variator setup allowing for continuously variable shifting.
Transmission Fluid
Check your moped's manual for the recommended transmission fluid and instructions on how to change it.
See also
Changing Tomos Gearbox Oil
This article is a stub.
You can help the Moped Wiki by expanding it.
Toolbox
