Honda PA Replacement Parts
From MopedWiki
Contents |
Replacement Parts
A number of parts remain available - but - it seems that not all local Honda shops can get them. Try these sources:
CDI Unit
The following CDI Units, from other Honda's will fit and work in your Hobbit:
- 1981
- NA50 Express II
- NC50 Express
- NX50M Express
- PA50II
- 1982
- NC50 Express
- NU50 Urban Express
- NU50M Urban Express Deluxe
- NX50M Express
- PA50II
- 1983
- NC50 Express
- PA50II
- NH80 Aero
- 1984
- NN50 Gyro
- NH80 Aero
- NH125 Aero
- 1985
- NH80 Aero
Head Light
DrATV.com has a headlight with a replaceable bulb. Headlight link
Pet Cock
DrATV.com has a petcock. Petcock linlk
Spark Plugs
Courtesy of http://www.itslookingup.com/moped/pa50/tyskpa50.htm
- PA50 1978 to 1981 (Gap 0.024 to .028")
- NGK BPR-6HS (OEM)
- Champion RL86C or L86C
- ND W20FPR
- PA50 1982 to 1983 (Gap .030")
- NGK BPR-6HS (OEM)
- Champion RL87YC or L87YC
- ND W20FPR
- Optional per Owner's Manual (all years): BPR-5HS
Note, the 1983 official factory manual from Honda does specifies resistor-type plugs. It has been reported that other years' manuals do not specify resistor-type plugs. Therefore, the correct spark plugs are NGK BP6HS, BP5HS, and ND W20FP. --mishan
"V" Belt
- The OEM belt length measured on the top side (outside diameter) is 41 inches (104.14 centimeters)
- The top and sides of the OEM belt (width) each measures 19/32 inch.
- The bottom width of the OEM belt measures 11/32 inch.
| Source | Model | Approx. Price | Comments |
| Mitsuboshi (OEM) | 23100-148-7030 | $60.00 | Available via Honda dealers |
| Dayco | #17415 or 13A055 | $12.00 | It is a 41.5" belt, slightly larger than stock |
| Goodyear | 17425 13AV1080 | $16 | Available at Shucks Autozone Carquest |
- I have tried the Dayco belt, and it does work. However, after a few hundred miles, the belt wore out. I suspect that the belt angle (the angle of the "V") is slightly different. The point --> don't expect a long life with this alternate belt.
Exhaust Gasket
I don't buy Honda parts - I just go to ebay for these. I usually do a search for "50" and "exhaust gasket". As long as the gasket is copper and about 1-1/4" across, it will usually work. Here's a pic from ebay:
| Honda PA50 Information |
| Main Article • Manuals • Model Info • Model Differences Carb/Fuel • Engine • Drivetrain • Wheels & Tires • Exhaust • Electrical • Body and Frame • PA50I/PA50M Performance • Troubleshooting • Parts • Tools |
