Honda PA Electrical
From MopedWiki
[edit]
Schematics
- Schematic with points - colorized version
- 1981 Schematic with CDI, Colorized version Note: Purple is used for G/Y.
- Example hardwire diagram for CDI
[edit]
Stator Tests
NOTE: These measurements were taken from good spares. They are not factory acceptance test numbers. I would expect that anything close is good, but something way off (like good is 1.8 and yours is 25) is bad.
ALSO: I had to measure several times to get consistent results. Don't just measure once, measure often, and once the readings are stable, use them.
[edit]
1978 to 1980
Resistance measurements for a stator (measured with the points open):
| Wire Color | Wire Color | Resistance (ohms) |
| Red | Green | 1.8 |
| Red | Yellow | 2.4 |
| Green | Yellow | 1.2 |
| Black/White | Green | 1.8 |
| Green | Frame (ground) | 0.0 |
[edit]
1981 to 1984
Resistance measurements for a stator and CDI pickup:
| Blue/Yellow | Green | 33 |
| Yellow | White | 1.2 |
| Yellow | Green | 1.1 |
| White | Green | 0.5 |
| Black/Red | Green | 231 |
[edit]
Coil testing sequence
[edit]
Battery
| Spec | Value |
| Volts | 6 Volt |
| Amps | 4 Amp |
| Size | 4"- x 1.875" x 3.75" |
| Type | 6N4B-2A-5 |
Batteries Plus: At Batteries Plus they now have a universal battery that replaces the older model. Model #: XT6N4B-2A-UNV
| Honda PA50 Information |
| Main Article • Manuals • Model Info • Model Differences Carb/Fuel • Engine • Drivetrain • Wheels & Tires • Exhaust • Electrical • Body and Frame • PA50I/PA50M Performance • Troubleshooting • Parts • Tools |
