Moped Wiki
Help:Basic Editing
From MopedWiki
Jump to: navigation, search
Contents
"What is this?! This doesn't look like the help page I remember!" If you're thinking that, have no fear: just click here.
Create A New Page
There are two ways to create a page, both very simple.
Method 1:
  • On a page that already exists, you can create a link to the page you want to create. For example, if you wanted to make a page about your gang, you could go to the Moped Army page and edit it with the following markup.
[[Your Gang]]
  • Then it will look like this: Your Gang.
  • Then click on the link and it will take you to a blank edit page where you can create your page.
Method 2:
  • In the search box on the left side of the page, type the desired name of the page you want to create.
  • If a page with that title already exists it will show up, if not you'll see a sentence that reads "There is no page titled "whatever you searched for". You can create this page. Click on the link that says "create this page" and a blank edit page will arise. Type away!
When to use which method?
  • Method 1 (placing a link on a page that already exists) is generally preferred, because the new page will already have a page linking to it. Method 2 will create "orphan pages" which have no pages linking to them - you'll have to go find a place to link from them if you want anyone to see it.
Important Note
  • Please do not use ampersands (&) in article titles -- everything after the & will be dropped, and then you'll be wondering where your article went.
Editing A Pre-existing Page
At the top of the page you will see four different "tabs." They are:
  • article
  • discussion
  • edit
  • history
  • move & watch are also present if you have a user name.
To edit the page you are on, click the "edit" tab and it will take you to the edit page.
Basic Wiki Markup
To get you started, here are the basics in Wiki markup language. MopedWiki's MediaWiki software (the same software that WikiPedia uses) supports some but not all HTML. Wiki language isn't hard either, just a bit different.
Text Formatting
What it looks like What you type
You can italicize text by putting two apostrophes on each side.
Three apostrophes will bold the text.
Five apostrophes will bold and italicize the text.
(Four apostrophes don't do anything special -- there's just 'one left over'.)
 You can ''italicize text'' by putting two
Three apostrophes will bold '''the text'''.
'''''the text'''''.
(4 apostrophes don't do anything
special -- there's just ''''one left
over''''.)
A single newline generally has no effect on the layout. These can be used to separate sentences within a paragraph. Some editors find that this aids editing and improves the diff function (used internally to compare different versions of a page).
But an empty line starts a new paragraph.
When used in a list, a newline does affect the layout.
and improves the ''diff'' function
When used in a list, a newline ''does''
affect the layout.
You can break lines
without a new paragraph.
Please use this sparingly.
Please do not start a link or italics or bold on one line and close it on the next.
You can break lines<br>
without a new paragraph.<br>
Please do not start a [[link]] or
''italics'' or '''bold''' on one line
The nowiki tag ignores Wiki '''markup'''. It reformats text by removing newlines and multiple spaces. It still interprets special characters: →
<nowiki>
Wiki '''markup'''.
removing
 spaces.
characters: &rarr;
</nowiki>
The pre tag ignores Wiki
 '''markup'''.
It also doesn't     reformat
 text.
characters: →
<pre>
 '''markup'''.
 text.
characters: &rarr;
</pre>
Leading spaces are another way to preserve formatting.
Putting a space at the
beginning of each
line stops the text
from being
reformatted. It still
interprets Wiki
markup and special
characters: →
 beginning of each
 line stops the text   from
 being
 interprets Wiki
 ''markup'' and special
 characters: &rarr;
HTML tags
You can use some HTML tags too. However, you should avoid HTML in favor of Wiki markup whenever possible.
Put text in a typewriter font. The same font is generally used for computer code.
Put text in a <tt>typewriter
font</tt>. The same font is
generally used for <code>
computer code</code>.
Strike out or underline text, or write it in small caps.
<strike>Strike out</strike>
or <u>underline</u> text,
or write it <span style=
"font-variant:small-caps">
in small caps</span>.
Superscripts and subscripts: X2, H2O
X<sup>2</sup>, H<sub>2</sub>O
Centered text
  • Please note the American spelling of "center". The British spelling "centre" will not work properly.
<center>Centered text</center>
The blockquote command will indent both margins when
needed instead of the left margin only as the colon does.
<blockquote>
The '''blockquote''' command will indent
both margins when needed instead of the
</blockquote>
Invisible comments to editors ( ) only appear while editing the page.
  • If you wish to make comments to the public, you should usually use the talk page.
Invisible comments to editors ( <!-- --> )
<!-- Note to editors: blah blah blah. -->
Organizing your writing
Section headings
Headings organize your writing into sections. The Wiki software can automatically generate a table of contents from them.
Subsection
Using more equals signs creates a subsection.
A smaller subsection
Don't skip levels, like from two to four equals signs.
Start with two equals signs not one because one creates H1 tags which should be reserved for page title.
== Section headings ==
''Headings'' organize your writing into
=== Subsection ===
==== A smaller subsection ====
Don't skip levels,
  • Unordered lists are easy to do:
    • Start every line with a star.
      • More stars indicate a deeper level.
    Previous item continues.
    • A newline
  • in a list
marks the end of the list.
  • Of course you can start again.
* ''Unordered lists'' are easy to do:
** Start every line with a star.
*** More stars indicate a deeper level.
*: Previous item continues.
** A newline
* in a list
* Of course you can start again.
  1. Numbered lists are:
    1. Very organized
    2. Easy to follow
A newline marks the end of the list.
  1. New numbering starts with 1.
# ''Numbered lists'' are also good:
## Very organized
## Easy to follow
# New numbering starts with 1.
Here's a definition list:
Word
Definition of the word
A longer phrase needing definition
Phrase defined
A word
Which has a definition
Also a second one
And even a third
Begin with a semicolon. One item per line; a newline can appear before the colon, but using a space before the colon improves parsing.
Here's a ''definition list'':
; Word : Definition of the word
; A longer phrase needing definition
: Phrase defined
; A word : Which has a definition
: Also a second one
: And even a third
parsing.
  • You can even do mixed lists
    1. and nest them
    2. inside each other
      • or break lines
        in lists.
      definition lists
      can be
      nested
      too
* You can even do mixed lists
*# and nest them
*# inside each other
*#* or break lines<br>in lists.
*#; definition lists
*#: can be
*#:; nested : too
A colon (:) indents a line or paragraph.
A newline starts a new paragraph.
Often used for discussion on talk pages.
We use 1 colon to indent once.
We use 2 colons to indent twice.
3 colons to indent 3 times, and so on.
: A colon (:) indents a line or paragraph.
A newline starts a new paragraph. <br>
: We use 1 colon to indent once.
:: We use 2 colons to indent twice.
::: 3 colons to indent 3 times, and so on.
You can make horizontal dividing lines (----) to separate text.
But you should usually use sections instead, so that they go in the table of contents.
to separate text.
Furthering the Wiki
Places That Need Some Love
Please see Rainy Day Edits for a list of places that need some love.
Core Principle of Wiki
One of the core principles of a Wiki is that everyone has an equal share in shaping it. Everyone can edit and that is part of the beauty of Wiki. MopedWiki needs your help to determine its course in the future. The best way to do this is to be bold and edit pages without fear. Don't worry about messing up pages because it's easy to fix, and there are other editors who are happy to help you.
Need More Help?
For more in-depth guides to specific types of editing, check out the links in the box below. You may find the articles listed there useful in your wikiventures.
If all else fails, leave a message here or shoot an e-mail here, and your questions will be answered.
MopedWiki Help Pages
IntroductionSearchingBasic EditingEditing (longer)LinksCategories
ImagesTablesTemplatesUserboxesRevertingStubsRainy Day Edits
Toolbox
