Moped Wiki
Decompression
From MopedWiki
(Redirected from Decompression lever)
Jump to: navigation, search
Decompression on a moped is achieved when you pull the decompression lever, opening a valve in your engine's Combustion chamber to allow a loss of compression so the piston can move much more freely in the cylinder for easier starting of the engine. Once the piston begins moving, the decompression lever is released and compression returns to the combustion chamber, allowing the motor to start. If the decompression valve is opened while the motor is running, compression will be lost and the motor will die.
This article is a stub.
You can help the Moped Wiki by expanding it.
Toolbox
