Compression ratio
From MopedWiki
Compression ratio measures compression as cylinder volume at BDC divided by cylinder volume at TDC. It is stated as a ratio in terms of X:1, where "X" is the quotient of volume at BDC divided by volume at TDC. This is a theoretical measurement used in designing an engine, it assumes optimal conditions and it does not reflect engine condition.
