Clutch puller
From Moped Wiki
Jump to: navigation, search
A clutch puller is a tool for removing a clutch from the end of a shaft (such as the crankshaft). It typically functions by fastening to the clutch and using a screw to exert pressure on the shaft to which it is mounted.
Puch Clutch Puller
"So, I don't know if you guys know already or not, but the handlebar mount of a Puch Maxi, and likely others doubles as a clutch puller. Simply pass the M6 bolts through the mount, and then place a socket, rock, or whatever you have between the mount and crankshaft as a press arbor. Now, screw down on those M6 screws until your clutch pops off. Trust me...works every time."
HINT: The stock mounting bolts on the bracket are M7s you're going to need to pick up 2 m6 bolts.
Goodluck!
Honda Hobbit Clutch Puller
There are two pullers available for the Honda Hobbit, One is a puller that only pulls the front variator while the other is a Honda made puller that does both rear and front variator.
The rear is 24MM X 1.0 RH
While the Front is 24mm x 1.5mm
Note that the flywheel does not need a puller however there is a piece that will need to be pulled with a three or two arm puller.
