Changing Tomos Gearbox Oil
From MopedWiki
(Redirected from Change gear box oil)
Jump to: navigation, search
Tomos A35
For the Tomos A35 use type A, or F, Automatic transmission fluid (ATF). You can pick up a bottle at any autoparts store.
To change gear box oil you drain the plug or bolt at the bottom of the transmission. The bolt on top of your transmission is for filling. There is a phillips head screw on the side unlike the allen heads that actually hold on the gearbox cover. Once you have drained the old oil, and bolted back on the bottom plug, fill new transmission fluid until it leaks out of the side where you have taken the phillips head off. Many recommend being very careful NOT to strip out the phillips head on the side, as it is not very strong metal. Use an appropriate sized phillips screwdriver.
This article is a stub. You can help the Moped Wiki by expanding it.
Red Arrow   Swarming and Destroying since 1997   |   Contact Us   |   Back to the top
