All Vespa Dimensions
From Moped Wiki
Jump to: navigation, search
This is a make-it-as-you-go page. I'm starting from memory, so if you find mistakes, help me out.
Engine
Cylinder Studs: M7x120mm
Case Bolts:
Mount Bolts: Two M6 x 120mm and one M6 x 30mm
Transmission
Rear Wheel Bolts: 10mm x 14mm 1.5 thread
Variator and Clutch
Weights: 14mm x 14mm
Variator Nut: 24mm or 17mm
Clutch Retaining Nut:
Clutch Assembly Nut: 24mm
Frame Rear Shock Nut: 17mm nut
Wheels Front Wheel: 17mm nut
Freewheel nut: 36mm
Brakes plate 105mm (The brake plates on both Grande/Bravo front wheels are 105mm, A ciao brake plate is the same 105mm the only difference is where the front end fits into the brake plate. On numerous occasions I’ve used Ciao wheels on Grandes but I did have to use the Grande brake plate. The brakes plates internally are the same the only difference, as I stated earlier, are the exterior front end clips - Ninja)
