Forums / Moped Performance
Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph
m b (mdb) — Jul 11, 2011 06:37PM
I got this 77 Mobat back in April. It was all stock and ran. At the time it probably topped out right around 25mph with zero mods, but a good going through.
Once I got it, I started doing my research. I read pretty much everything on this site and forum about the M48 Engine, and possible Batavus mods and improvements.
So, over the past few months it's been slow going, but I finally have it up and running again. I know I should have done the upgrades incrementally instead of all at once, but live and learn.
It's the Laura M48 Engine. I upgraded the carb to a Delorto SHA 15.15 and used the modified intake. I also bought a hi-flow air filter, but it turns out it doesn't fit in the space provided, so that's running the stock filter for that carb. I did the reed block modification so that's been opened up and now has the carbon reeds.
Finally, I put on a Proma GP chamber on there. This is the one spot that I'm thinking the trouble might be coming from, but I'm not sure. At the time, treats only had the 32mm chamber, and I was impatient, and after doing research, I thought I could just get a bushing made, or make it work with a pipe clamp. Little did I realize that my header pipe which I am using, is actually 22mm, not 26mm like I thought it was. So there is a 10mm difference in the header and chamber. I'm currently using a pipe clamp and some rubber as a bushing to make up for the difference. It fits pretty tight, and the chamber is supported in the back, so it's not going anywhere, but there is definitely air leak from around the chamber and header connection. Is that air leak enough to hurt my over all power? Or is the 22mm stock header keeping me back, or neither?
I also upjetted to a 68. Anything below and it died when trying to start from a standstill.
So I guess my question is, how come after all these mods, I'm still not getting any more power out of the thing? I know I probably need more compression because of the mods, and that's why the low end sucks, but I just don't have the resources to do that mod yet. There is also the clutch mod that I haven't done yet. So yeah. I know it's long winded, but any thoughts or tips would be appreciated.
Thanks!
  Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/11/11 06:37PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Quinn Welch 07/12/11 02:21AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/12/11 12:44PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Jesse Brosnan 07/13/11 09:33PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Ryan Mayer 07/13/11 10:21PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/15/11 02:33PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/15/11 02:46PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Ryan Werling 07/16/11 12:13AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/16/11 04:06AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Chip _ 07/16/11 07:03AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/16/11 02:49PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Zeke Rigg 07/17/11 11:27AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Max (ツ) 07/19/11 10:53AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/17/11 10:05PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/19/11 12:23PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Ray Kelley 07/19/11 12:28PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/19/11 04:45PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Scott Terwiel 07/20/11 03:09AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Tim Radder 07/20/11 01:12PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Jason T 07/20/11 01:45PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/20/11 02:53PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Nathaniel Almeida 07/20/11 03:07PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/20/11 08:15PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph ♣Slew Foot♣ 07/22/11 03:49AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph ♣Slew Foot♣ 07/22/11 03:55AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Nathaniel Almeida 07/22/11 04:24AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph ♣Slew Foot♣ 07/22/11 11:49AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Jason T 07/22/11 02:27PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph ♣Slew Foot♣ 07/22/11 08:35PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph ♣Slew Foot♣ 07/23/11 06:14AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 07/31/11 12:51PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Rob @t ATTN! Burrito 07/31/11 06:31PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph ♣Slew Foot♣ 08/02/11 03:38AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Marla Wisuri 08/02/11 04:57AM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Dimitri K 08/22/11 06:32PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Jesse -B 08/23/11 07:37PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 08/24/11 10:40PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph m b 08/26/11 01:01PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Van Cleave 04/27/12 08:19PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph - Summerai - GB_Drew 04/28/12 02:41PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph ♣Slew Foot♣ 04/28/12 04:10PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Graham Motzing 04/29/12 01:46PM
  Re: Batavus Mobat with new carb, reed block, and pipe still tops out at 26mph Mike Mills 08/24/12 09:57PM
Click here to login.
