Forums / Moped Performance
Re: KTM @ e50: Well that was easy
Mark Zielstorff (marozie) — Sep 20, 2011 11:53AM
Rachid - I'm planning on using the regular starting mechanism, like what Cooper did with the BRN clutch set up he posted earlier. I'm going to attach friction material to the sides of the KTM arms for the starting plate to grab against.
I don't know, removing more material, especially from the side walls of the bell would make me a bit nervous. Think about the centrifugal force pulling everything outward. I don't think the aluminum ring, attached just with 6 set screws is going to hold back the steel bell from wanting to expand. If I were welding in a steel ring maybe.
Ricky - I don't know, 10 bucks? If you're making a pull start though why don't you just use a KTM bell? It would be so much lighter. The main reason for doing this is so that you can use the rest of the stock transmission w/ the starting mechanism.
  KTM @ e50: Well that was easy Mars™   06/24/11 11:08PM
  Re: KTM @ e50: Well that was easy los terrydean 06/24/11 11:28PM
  Re: KTM @ e50: Well that was easy Ryan Lawton 06/24/11 11:42PM
  Re: KTM @ e50: Well that was easy Ricky Lacapria 06/25/11 04:23AM
  Re: KTM @ e50: Well that was easy Frank Horrigan 06/25/11 04:44AM
  Re: KTM @ e50: Well that was easy Ryan Steel 06/25/11 05:43AM
  Re: KTM @ e50: Well that was easy Mo Peds 06/25/11 09:12AM
  Re: KTM @ e50: Well that was easy Mars™   06/25/11 09:46AM
  Re: KTM @ e50: Well that was easy K Olena 09/08/11 09:19PM
  Re: KTM @ e50: Well that was easy Mo Peds 06/25/11 10:48AM
  Re: KTM @ e50: Well that was easy Mars™   06/25/11 11:47AM
  Re: KTM @ e50: Well that was easy bully -+:| 06/25/11 12:24PM
  Re: KTM @ e50: Well that was easy derbeez ryderz 06/25/11 05:57PM
  Re: KTM @ e50: Well that was easy Grey L 06/25/11 06:25PM
  Re: KTM @ e50: Well that was easy Mars™   06/25/11 06:48PM
  Re: KTM @ e50: Well that was easy Max Dickford 06/25/11 09:43PM
  Re: KTM @ e50: Well that was easy The Hebrew Hammer 06/25/11 09:48PM
  Re: KTM @ e50: Well that was easy Cooper Hennick 06/26/11 07:05PM
  Re: KTM @ e50: Well that was easy Derk Jan Ter Veen 09/13/11 10:10AM
  Re: KTM @ e50: Well that was easy derbeez ryderz 06/26/11 08:32PM
  Re: KTM @ e50: Well that was easy los terrydean 06/26/11 08:33PM
  Re: KTM @ e50: Well that was easy Sadder Joey P 06/27/11 03:04AM
  Re: KTM @ e50: Well that was easy ( ͡° ͜ʖ ͡° ) 06/27/11 08:30AM
  Re: KTM @ e50: Well that was easy GET REAL YOU BLEW IT 09/08/11 10:19PM
  Re: KTM @ e50: Well that was easy K Olena 09/09/11 03:02PM
  Re: KTM @ e50: Well that was easy Grey L 09/09/11 03:09PM
  Re: KTM @ e50: Well that was easy Mars™   09/09/11 03:48PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/09/11 11:17PM
  Re: KTM @ e50: Well that was easy Cooper Hennick 09/11/11 01:35PM
  Re: KTM @ e50: Well that was easy Mars™   09/11/11 05:27PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/09/11 11:18PM
  Re: KTM @ e50: Well that was easy Blake Freed 09/10/11 10:11PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/12/11 04:40PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/12/11 10:40PM
  Re: KTM @ e50: Well that was easy Cooper Hennick 09/12/11 11:53PM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/12/11 11:51PM
  Re: KTM @ e50: Well that was easy Cooper Hennick 09/12/11 11:54PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/13/11 11:00AM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/13/11 11:15AM
  Re: KTM @ e50: Well that was easy Derk Jan Ter Veen 09/13/11 12:39PM
  Re: KTM @ e50: Well that was easy Mo Peds 09/13/11 12:53PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/13/11 12:56PM
  Re: KTM @ e50: Well that was easy Mo Peds 09/13/11 12:58PM
  Re: KTM @ e50: Well that was easy Hell yea it's WillD SWOOP 09/13/11 02:13PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/14/11 09:40AM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/14/11 10:13AM
  Re: KTM @ e50: Well that was easy Mars™   09/14/11 10:18AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/14/11 10:31AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/14/11 10:41AM
  Re: KTM @ e50: Well that was easy Cooper Hennick 09/14/11 07:09PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/14/11 10:45PM
  Re: KTM @ e50: Well that was easy Scott Terwiel 09/15/11 07:40AM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/15/11 09:30AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/15/11 01:11PM
  Re: KTM @ e50: Well that was easy Cooper Hennick 09/15/11 01:34PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/15/11 02:37PM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/15/11 01:27PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/15/11 01:29PM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/15/11 03:06PM
  Re: KTM @ e50: Well that was easy Jake P 09/15/11 05:02PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/15/11 09:10PM
  Re: KTM @ e50: Well that was easy Jake P 09/15/11 09:17PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/15/11 09:21PM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/15/11 10:30PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/16/11 02:35PM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/16/11 05:14PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/16/11 08:31PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/19/11 10:52PM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/19/11 11:27PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/20/11 07:48AM
  Re: KTM @ e50: Well that was easy Rachid Z 09/20/11 11:06AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/20/11 11:53AM
  Re: KTM @ e50: Well that was easy Ricky Lacapria 09/20/11 11:14AM
  Re: KTM @ e50: Well that was easy Ricky Lacapria 09/20/11 12:26PM
  Re: KTM @ e50: Well that was easy Bryan Colliver 09/20/11 12:27PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/20/11 12:37PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/20/11 10:22PM
  Re: KTM @ e50: Well that was easy Adam Russell 09/21/11 12:56PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/21/11 01:22PM
  Re: KTM @ e50: Well that was easy Mars™   09/21/11 01:49PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/21/11 02:37PM
  Re: KTM @ e50: Well that was easy Mars™   09/21/11 03:13PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/21/11 03:31PM
  Re: KTM @ e50: Well that was easy Flagrant - 09/21/11 05:31PM
  Re: KTM @ e50: Well that was easy Todd rod 09/21/11 06:37PM
  Re: KTM @ e50: Well that was easy nate backner 09/21/11 09:59PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/21/11 10:12PM
  Re: KTM @ e50: Well that was easy Mars™   09/22/11 01:07AM
  Re: KTM @ e50: Well that was easy Adam Russell 09/22/11 07:37AM
  Re: KTM @ e50: Well that was easy Adam Russell 09/22/11 07:57AM
  Re: KTM @ e50: Well that was easy Mars™   09/22/11 08:34AM
  Re: KTM @ e50: Well that was easy Adam Russell 09/22/11 09:48AM
  Re: KTM @ e50: Well that was easy Mars™   09/22/11 09:51AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/22/11 10:00AM
  Re: KTM @ e50: Well that was easy Mars™   09/22/11 10:10AM
  Re: KTM @ e50: Well that was easy Drew Bell 09/22/11 10:12AM
  Re: KTM @ e50: Well that was easy Mars™   09/22/11 11:37AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/22/11 01:14PM
  Re: KTM @ e50: Well that was easy Drew Bell 09/22/11 06:47PM
  Re: KTM @ e50: Well that was easy Cooper Hennick 09/22/11 08:57PM
  Re: KTM @ e50: Well that was easy Drew Bell 09/23/11 06:21PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/22/11 10:32AM
  Re: KTM @ e50: Well that was easy Adam Russell 09/22/11 10:49AM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/22/11 01:04PM
  Re: KTM @ e50: Well that was easy RingringBANG ! 09/22/11 01:20PM
  Re: KTM @ e50: Well that was easy Mars™   09/22/11 02:00PM
  Re: KTM @ e50: Well that was easy Ricky Lacapria 09/22/11 02:10PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/22/11 02:59PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/22/11 03:11PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/22/11 03:25PM
  Re: KTM @ e50: Well that was easy Adam Russell 09/22/11 07:17PM
  Re: KTM @ e50: Well that was easy Ricky Lacapria 09/22/11 07:19PM
  Re: KTM @ e50: Well that was easy Adam Russell 09/22/11 08:20PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/22/11 08:25PM
  Re: KTM @ e50: Well that was easy Rachid Z 09/25/11 11:19AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/25/11 10:52PM
  Re: KTM @ e50: Well that was easy Rachid Z 09/25/11 11:06PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/25/11 11:19PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/25/11 11:21PM
  Re: KTM @ e50: Well that was easy Rachid Z 09/26/11 12:08AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/26/11 09:53AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/26/11 11:07AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 09/30/11 04:35PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 10/02/11 08:29PM
  Re: KTM @ e50: Well that was easy Rachid Z 10/02/11 09:58PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 10/02/11 10:13PM
  Re: KTM @ e50: Well that was easy David Romo 10/02/11 10:19PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 10/02/11 10:25PM
  Re: KTM @ e50: Well that was easy RingringBANG ! 10/03/11 09:55AM
  Re: KTM @ e50: Well that was easy Mars™   10/03/11 10:17AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 10/03/11 10:27AM
  Re: KTM @ e50: Well that was easy RingringBANG ! 10/03/11 10:36AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 10/03/11 10:38AM
  Re: KTM @ e50: Well that was easy The Hebrew Hammer 11/23/11 10:25PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 11/23/11 10:33PM
  Re: KTM @ e50: Well that was easy Chris HnRz 11/25/11 02:56AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 10/03/11 10:25AM
  Re: KTM @ e50: Well that was easy Jake P 06/07/12 07:53PM
  Re: KTM @ e50: Well that was easy T S 11/05/11 03:38AM
  Re: KTM @ e50: Well that was easy Rachid Z 11/23/11 08:26PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 11/23/11 08:40PM
  Re: KTM @ e50: Well that was easy Rachid Z 11/23/11 08:44PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 11/23/11 09:19PM
  Re: KTM @ e50: Well that was easy Rachid Z 11/23/11 10:07PM
  Re: KTM @ e50: Well that was easy Rachid Z 02/06/12 10:19PM
  Re: KTM @ e50: Well that was easy Mars™   02/06/12 10:28PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 03/23/12 01:23PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 02/07/12 10:18AM
  Re: KTM @ e50: Well that was easy Jake P 07/11/12 05:06PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 07/11/12 05:14PM
  Re: KTM @ e50: Well that was easy Rachid Z 08/20/12 09:01PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 08/20/12 10:17PM
  Re: KTM @ e50: Well that was easy Rachid Z 08/23/12 12:00PM
  Re: KTM @ e50: Well that was easy Professor Sheiklestein 08/23/12 12:58PM
  Re: KTM @ e50: Well that was easy Rachid Z 08/23/12 03:56PM
  Re: KTM @ e50: Well that was easy RingringBANG ! 08/23/12 04:44PM
  Re: KTM @ e50: Well that was easy Cooper Hennick 08/23/12 09:57PM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 08/23/12 10:35PM
  Re: KTM @ e50: Well that was easy Cooper Hennick 08/24/12 09:36AM
  Re: KTM @ e50: Well that was easy RingringBANG ! 08/24/12 10:27AM
  Re: KTM @ e50: Well that was easy Mark Zielstorff 08/23/12 01:08PM
Click here to login.
