Forums / Moped Performance
64cc Polini / E50 / 19 Del' help..
Andre Hummer (subtle) — Aug 31, 2010 12:36AM
First time going out today with this kit, attempting to tune it on an empty country road.
Modesto, Ca. 92ft Above sea level
Setup:
64cc Polini (ports matched to the case, nothing more)
E50 Super Stuffy Crank + new seals.
Malossi 4 Petal.
Stock 2 shoe Clutch.
Boss Pipe.
19 PHBG Dellorto Carb.
First off:
back wheel spins fast after it's warmed up, so i cant get it to idle slow or else it will die out, (no air leaks, triple checked with carb cleaner, doesn't bogg at all) also adjusted my slide cable tension, still nothing...
I'm assuming polini's don't idle on the stand at all?
so my first test run:
125 main
45 idle
2 stroke atomizer with the disk on it
w7 needle at the 2nd from leanest
sputters half throttle, but can pick up speed quarter throttle fast, nothing more..
plug chop was grey
2nd test run:
115 main
50 idle
2nd notch
plug chop was still lean
3rd test run:
125 main
50 idle
3rd notch needle
sputters at quarter throttle...
I can't seem it figure this out, I've did more tests, plug ends up being black & dry or grey & dry. cant get to that brown color.
but when i was packing the bike up, i let all the fuel out the tank then rode the bike around till it ate up the rest of the gas in the carb, died, then plug chopped that just to see and it was wet and dark..
any help? or similarity's i can copy just to start off my tunning with?
  64cc Polini / E50 / 19 Del' help.. Andre Hummer 08/31/10 12:36AM
  Re: 64cc Polini / E50 / 19 Del' help.. Nick Chames 08/31/10 12:44AM
  Re: 64cc Polini / E50 / 19 Del' help.. ∴ Μ Λ Ι Ζ Σ ∴ 08/31/10 12:53AM
  Re: 64cc Polini / E50 / 19 Del' help.. Andre Hummer 08/31/10 12:56AM
  Re: 64cc Polini / E50 / 19 Del' help.. gabby 08/31/10 01:25AM
  Re: 64cc Polini / E50 / 19 Del' help.. Cold Trailer GARzan Justin 08/31/10 01:12AM
  Re: 64cc Polini / E50 / 19 Del' help.. Andre Hummer 08/31/10 01:17AM
  Re: 64cc Polini / E50 / 19 Del' help.. sonny sonny 08/31/10 01:22AM
  Re: 64cc Polini / E50 / 19 Del' help.. sonny sonny 08/31/10 01:34AM
  Re: 64cc Polini / E50 / 19 Del' help.. Andre Hummer 08/31/10 01:32AM
  Re: 64cc Polini / E50 / 19 Del' help.. gabby 08/31/10 02:36AM
  Re: 64cc Polini / E50 / 19 Del' help.. sonny sonny 08/31/10 02:41AM
  Re: 64cc Polini / E50 / 19 Del' help.. gabby 08/31/10 02:50AM
  Re: 64cc Polini / E50 / 19 Del' help.. sonny sonny 08/31/10 03:04AM
  Re: 64cc Polini / E50 / 19 Del' help.. Joshua Franta 08/31/10 03:13AM
  Re: 64cc Polini / E50 / 19 Del' help.. Andre Hummer 08/31/10 03:39AM
  Re: 64cc Polini / E50 / 19 Del' help.. ) Cupermcnewbster ( 08/31/10 03:47AM
  Re: 64cc Polini / E50 / 19 Del' help.. Andre Hummer 08/31/10 03:59AM
  Re: 64cc Polini / E50 / 19 Del' help.. ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 08/31/10 08:14AM
  Re: 64cc Polini / E50 / 19 Del' help.. Andre Hummer 08/31/10 01:45PM
  Re: 64cc Polini / E50 / 19 Del' help.. Andre Hummer 08/31/10 01:46PM
  Re: 64cc Polini / E50 / 19 Del' help.. Andre Hummer 09/01/10 12:53AM
  Re: 64cc Polini / E50 / 19 Del' help.. ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 09/01/10 05:18AM
  Re: 64cc Polini / E50 / 19 Del' help.. Andre Hummer 09/01/10 11:29PM
  64cc Polini / E50 / 19 Del' Update Andre Hummer 10/04/10 10:28PM
  Re: 64cc Polini / E50 / 19 Del' Update ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 10/04/10 10:37PM
  Re: 64cc Polini / E50 / 19 Del' Update Crazy Wayne Treats Rock's 10/04/10 10:53PM
  Re: 64cc Polini / E50 / 19 Del' Update Andre Hummer 10/04/10 11:19PM
  Re: 64cc Polini / E50 / 19 Del' Update Cooper 10/05/10 01:28AM
  Re: 64cc Polini / E50 / 19 Del' Update Brian Brickner 10/05/10 04:16PM
  Re: 64cc Polini / E50 / 19 Del' Update damengual 10/06/10 09:56AM
  Re: 64cc Polini / E50 / 19 Del' Update Andre Hummer 10/06/10 01:36PM
  Re: 64cc Polini / E50 / 19 Del' Update Crazy Wayne Treats Rock's 10/06/10 10:50PM
Click here to login.
