HELP!!!HONDA EXPRESS NX50 SR build
i am re building a 82 honda express sr.
it has a pully/weight clutch system "similar to dio motor"
cdi also.
motor is off the bike but cant get the flywheel / clutch off and also the front pulley "i dont have an impact" tried a cheap strap wrench didnt work "broke" what tools do i need to get to correctly remove these??? "from the honda dealer??"
also will my ped over heat with these parts"is the carb big enough??"
i live in hawaii so its 80's all day. Over all i want it to go 40's and be reliable for every day use.
>i wanna put a
>dio reed kit/ manifold "77mopeds"
>21mm oko carb "ebay"
>ev exhaust "77mopeds"
>cheapo aluminum kit "77mopeds"
>pully weights "need help on what size to use"
>new clutch springs "what ones to use as there is a big one arround drive shaft and smaller ones on clutch??"
cdi also.
>i wanna put a
