Forums / Moped Performance
Alukit Tomos bog issue- Help me out
Chris Rice ( chrisr) — Nov 19, 2009 03:13PM
I got my first Tomos recently. 94 Targa Step through with 460 original miles. Ran great stock.
Put on an Alukit, with the JCams intake/Mikuni setup, Malossi Reed block from treats and an Estoril pipe.
Started with a 145 main jet. Starts right up and idles perfect, but when I give it gas, it bogs and dies. Upjetted to 175, same thing. Removed air filter, same thing. I'm just wondering if it's something obvious.
I've heard the jet range is 145-175 on these setups so that is why I chose that range...
If it wasn't running fine stock, I would be thinking it's a blown seal.
My lack of Tomos and Mikuni knowledge brings me here. I did some searches and didn't find anything...
Also, what petcock are people using with this setup on a stepthrough. Mine is all up in my cylinder in the only position that allows me to install the kit with this intake and carb setup, stuck on reserve.
Thanks in advance.
Chris
  Alukit Tomos bog issue- Help me out Chris Rice 11/19/09 03:13PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/19/09 03:24PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/19/09 03:39PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/19/09 03:40PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/19/09 03:43PM
  Re: Alukit Tomos bog issue- Help me out daddy weeder 11/19/09 03:48PM
  Re: Alukit Tomos bog issue- Help me out daddy weeder 11/19/09 03:52PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/19/09 04:23PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/19/09 04:25PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/19/09 05:40PM
  Re: Alukit Tomos bog issue- Help me out RingringBANG ! 11/19/09 05:52PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/19/09 05:56PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/19/09 08:36PM
  Re: Alukit Tomos bog issue- Help me out Weak-Ends Tj 11/20/09 12:06AM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/20/09 12:20PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/20/09 12:21PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/20/09 03:17PM
  Re: Alukit Tomos bog issue- Help me out Graham Motzing 11/20/09 04:17PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/20/09 04:57PM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/20/09 05:23PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/20/09 05:26PM
  Re: Alukit Tomos bog issue- Help me out Graham Motzing 11/20/09 06:02PM
  Re: Alukit Tomos bog issue- Help me out ryan 11/20/09 06:12PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/20/09 08:15PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/20/09 08:13PM
  Re: Alukit Tomos bog issue- Help me out Southern Dandy JCams 11/20/09 06:59PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/20/09 08:18PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/20/09 08:19PM
  Re: Alukit Tomos bog issue- Help me out Weak-Ends Tj 11/22/09 12:48PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/22/09 04:12PM
  Re: Alukit Tomos bog issue- Help me out Weak-Ends Tj 11/22/09 04:23PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/22/09 04:14PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/22/09 04:25PM
  Re: Alukit Tomos bog issue- Help me out Weak-Ends Tj 11/22/09 04:28PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/22/09 07:04PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/22/09 06:54PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/22/09 07:34PM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/22/09 08:14PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/22/09 09:11PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/22/09 09:23PM
  Re: Alukit Tomos bog issue- Help me out ryan 11/22/09 11:20PM
  Re: Alukit Tomos bog issue- Help me out Weak-Ends Tj 11/22/09 11:41PM
  Re: Alukit Tomos bog issue- Help me out RingringBANG ! 11/22/09 09:33PM
  Re: Alukit Tomos bog issue- Help me out Gabe Bandit 11/22/09 11:46PM
  Re: Alukit Tomos bog issue- Help me out Weak-Ends Tj 11/22/09 11:53PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/22/09 11:55PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/23/09 12:16AM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/23/09 12:30AM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/23/09 12:41AM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/23/09 01:10AM
  Re: Alukit Tomos bog issue- Help me out Southern Dandy JCams 11/23/09 01:20AM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/23/09 01:28AM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/23/09 01:26AM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/23/09 01:37AM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/23/09 02:17AM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/23/09 02:50AM
  Re: Alukit Tomos bog issue- Help me out Gabe Bandit 11/23/09 02:47AM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/23/09 02:51AM
  Re: Alukit Tomos bog issue- Help me out ) Cupermcnewbster ( 11/23/09 03:41AM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/23/09 03:57AM
  Re: Alukit Tomos bog issue- Help me out zeke 11/23/09 08:54AM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/23/09 10:27AM
  Re: Alukit Tomos bog issue- Help me out tweeder 11/23/09 12:18PM
  Re: Alukit Tomos bog issue- Help me out Graham Motzing 11/23/09 12:26PM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/23/09 01:56PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/24/09 06:27PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/24/09 06:33PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/23/09 01:08PM
  Re: Alukit Tomos bog issue- Help me out pauld 11/23/09 01:31PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/24/09 06:36PM
  Re: Alukit Tomos bog issue- Help me out Weak-Ends Tj 11/24/09 06:46PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/24/09 06:49PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/24/09 07:24PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/24/09 08:20PM
  Re: Alukit Tomos bog issue- Help me out A55er 11/24/09 08:29PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/25/09 01:27AM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/25/09 01:44AM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/25/09 06:31PM
  Re: Alukit Tomos bog issue- Help me out Graham Motzing 11/25/09 11:55AM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/25/09 12:55PM
  Re: Alukit Tomos bog issue- Help me out Graham Motzing 11/25/09 01:36PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/25/09 09:43PM
  Re: Alukit Tomos bog issue- Help me out Graham Motzing 11/28/09 09:39PM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/28/09 11:43PM
  Re: Alukit Tomos bog issue- Help me out Ryan 11/29/09 12:21AM
  Re: Alukit Tomos bog issue- Help me out mattology - 11/29/09 11:05AM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/29/09 03:49PM
  Re: Alukit Tomos bog issue- Help me out Uphill Nate 11/29/09 04:22PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 11/30/09 07:31PM
  Re: Alukit Tomos bog issue- Help me out . (Nick) 11/29/09 10:10PM
  Re: Alukit Tomos bog issue- Help me out Graham Motzing 11/30/09 01:07PM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/30/09 05:22PM
  Re: Alukit Tomos bog issue- Help me out marshall 11/30/09 07:43PM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 11/30/09 08:41PM
  Re: Alukit Tomos bog issue- Help me out Crazy Wayne Treats Rock's 12/22/09 01:48PM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 12/01/09 11:51AM
  Re: Alukit Tomos bog issue- Help me out Chris Rice 12/01/09 11:56AM
  Re: Alukit Tomos bog issue- Help me out tweeder 12/01/09 12:05PM
  Re: Alukit Tomos bog issue- Help me out rjimmy 01/21/10 12:46AM
Click here to login.
