Forums / Moped Performance
FINALLY! PUCH 5-Star Bolt on disks....
Mike Thomas ( michaelt) — Nov 17, 2009 03:22PM
So this stemmed from a solution for disk brakes on my Sebring where I ran into issues with the factory 5-star. I looked to the popular Puch 5-star with its bolt together goodness. From there I produced a custom disk as well as spacers to give the require backspacing needed. Add five 8mm x 70mm bolts(which i am sourcing ones with low profile heads), lock-washers and coupling nuts and bam! Bolt on disk brakes! Now these are designed for Tomos or EBR disk brake forks but you could probably use the different spacers to accommodate a weld on bracket to your own forks. Im also using a sealed bearing hub so I would recommend a bearing conversion or longer axle for your loose bearing setups. From there I just use standard ol' tomos calipers, axle, and hardware. I have already had in production the Disk's for the Italian style wheels with the "Z" pattern and will gladly develop them for other wheels like the tomos ones if there is a demand. Let me know if you are interested in this.
PS: I know our community is an extremely resourceful one and there will be alot of pushback saying that you could make it yourself, true, but as someone who has taken the time to develop a set, I could tell you a one off solution will probably cost you much more and not bolt up as cleanly as this.
Images are here: <http://gallery.me.com/mike.thomas1#100170>;
contact me at: mike@mopedskunkworks.com
  FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/17/09 03:22PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mattology - 11/17/09 03:38PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/17/09 03:50PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 11/17/09 03:53PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mattology - 11/17/09 03:54PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/17/09 03:57PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/17/09 04:02PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mattology - 11/17/09 04:12PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/17/09 04:16PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... math labs 11/17/09 06:13PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Poo 11/17/09 06:53PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... logan cain 11/17/09 07:49PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Tate 11/17/09 08:27PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... retrorider 11/17/09 08:37PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Jon 11/17/09 08:58PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Poo 11/17/09 09:09PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... RingringBANG ! 11/17/09 09:19PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Poo 11/17/09 09:38PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mattology - 11/17/09 09:47PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... logan cain 11/19/09 06:46PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/17/09 09:57PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/17/09 10:00PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... todd Posadas 11/17/09 10:19PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... todd Posadas 11/17/09 10:21PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Tate 11/17/09 10:24PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Poo 11/17/09 10:32PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... ) Cupermcnewbster ( 11/18/09 12:17AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... seniorita apocalypsegato 11/18/09 12:28AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... The Hebrew Hammer 11/18/09 12:37AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... a n d y 11/18/09 01:09AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... a n d y 11/18/09 01:18AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... todd Posadas 11/18/09 01:26AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... RingringBANG ! 11/18/09 01:34AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Poo 11/18/09 01:52AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... IRE Tom 11/18/09 02:58AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Jax Rhapsody 11/18/09 03:24AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... ) Cupermcnewbster ( 11/18/09 04:14AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... A-ko on his friends account 11/18/09 04:22AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mattology - 11/18/09 07:21AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Jon 11/18/09 07:17PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike 11/18/09 07:33PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... SABAT! 11/18/09 07:43PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/18/09 10:56PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Jon 11/19/09 03:05AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Graham Motzing 11/19/09 10:29AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/19/09 06:24PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/19/09 08:34PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/19/09 08:35PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... a n d y 11/20/09 12:46AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Napalm Beth 11/20/09 10:42PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/20/09 11:30PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/20/09 11:31PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/23/09 01:38AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... RingringBANG ! 11/25/09 12:36AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... coco 11/25/09 06:00AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... sunset chick 11/25/09 02:14PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... poopoo 11/25/09 03:23PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... poopoo 11/25/09 03:26PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 11/27/09 02:34AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... miket 12/06/09 12:10AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... coco 12/06/09 12:33AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... PYTelliott 12/06/09 03:29PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Arms Swoop 12/06/09 05:54PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Crazy Wayne Treats Rock's 12/06/09 06:00PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Chelsea Myers 12/14/09 01:13AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... None of your business 12/07/09 03:40AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... MotorCityMarc -> 12/07/09 04:29PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 12/16/09 02:54AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 12/16/09 12:11PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 12/25/09 03:35AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 12/25/09 12:04PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... cocoloco 12/25/09 12:31PM
  FINALLY! PUCH 5-Star Bolt on disks.... Jake Harvey 12/26/09 04:08PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... cocoloco 12/26/09 05:19PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mthomas 12/26/09 05:37PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mthomas 12/26/09 05:38PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mthomas 12/26/09 05:39PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 12/27/09 03:10AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Jon Folks 12/27/09 01:49PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Jake Harvey 12/28/09 10:49AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... RingringBANG ! 12/29/09 03:11AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... ) Cupermcnewbster ( 12/29/09 03:12AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 12/29/09 10:41AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... ) Cupermcnewbster ( 12/29/09 01:10PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... miket 12/29/09 01:43PM
  FINALLY! PUCH 5-Star Bolt on disks.... crazyjay vandal 01/02/10 12:54AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Z 01/02/10 04:45PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 01/03/10 09:26PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... crazyjay vandal 01/04/10 06:02PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 01/07/10 08:36PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mike Thomas 01/08/10 01:56AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Marco Last Name 01/29/10 03:57PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Dedic761 02/16/11 03:42PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Dedic761 02/17/11 03:39PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Dedic761 02/22/11 02:50PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Jon 01/15/10 02:07AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 01/15/10 03:29AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Los Dean 01/15/10 03:57AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Jon 01/15/10 04:07AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Jon 01/15/10 04:08AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... comedy shorts 01/29/10 04:11PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Marco Last Name 01/29/10 05:15PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Chelsea 01/29/10 09:43PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... treatshqmasterofshippingdept 02/01/10 04:20PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Mustachio 02/01/10 06:18PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 02/07/10 12:51AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike Thomas 02/07/10 03:57AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 02/07/10 03:43PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 02/07/10 03:51PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 02/15/10 05:17PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike 02/15/10 05:36PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... TD 02/15/10 06:21PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Señor Chingas 10/29/10 04:55PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike Thomas 02/15/10 09:12PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... TD 02/15/10 09:47PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike Thomas 02/16/10 12:56AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... TD 02/16/10 01:12AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike Thomas 02/16/10 02:28AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 02/18/10 10:42PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 02/18/10 11:35PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... TD 02/19/10 12:20AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike Thomas 02/19/10 02:13PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 02/19/10 10:54PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Cappy 03/02/10 04:08AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike Thomas 03/02/10 04:37AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... The Hebrew Hammer 04/02/10 01:55PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike Thomas 04/02/10 04:59PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... The Hebrew Hammer 04/02/10 07:25PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike Thomas 04/02/10 08:26PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mr thomas 10/29/10 07:38PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Señor Chingas 10/29/10 09:49PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike 02/16/11 04:25PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... david R. 02/17/11 02:19AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... c 02/17/11 10:13AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Dick Tortuga 02/17/11 10:56AM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike 02/22/11 07:06PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... chris! C 03/24/11 09:09PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Todd Bailes 04/28/11 05:07PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Downhill Harvey 04/28/11 06:14PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... mike 03/24/11 09:35PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Aron 03/24/11 10:56PM
  Re: FINALLY! PUCH 5-Star Bolt on disks.... Dan Webber Kastner 05/06/11 02:36PM
Click here to login.
