Forums / Moped Performance
gilarini
mattology - (mattology) — Nov 12, 2009 02:34PM
this weekend i'm going to port my gilardoni and turn it into a polini. adding the two additional long intake ports, cutting into the skirt sleeve and adding the top style transfers, and giving the piston more vents and wat not. i might also cut in the third eye instead in order to do this. and not require as many massive breathing holes through the piston. i might as well also drill two lubrication holes on either side of the edges of the exhaust port, where seizing likes to happen if you're too lean or hot. i'd do the 'big block fiero' +7000 HP lateral gas ports on the ring but i'm not sure how this L ring would like that.
this cylinder is a piece of junk, i might as well make it more junky. I might move the pin location to the intake side, between a boost and a transfer port or something. i don't know if i can get the exhaust as big as i need it to be (33mm) with the stupid factory pin location, but we will see. i'm going to get this bastard to go straight to plaid. since these reeds are designed to work with 360 degree intake timing, maybe this will work.
probably not. i'll probably just throw it at someone when it doesn't.
  gilarini mattology - 11/12/09 02:34PM
  Re: gilarini The Hebrew Hammer 11/12/09 02:50PM
  Re: gilarini ezdasnowman! 11/12/09 10:29PM
  Re: gilarini DWOB 11/12/09 10:36PM
  Re: gilarini Jesse -B 11/13/09 08:28AM
  Re: gilarini Max Mojo 11/13/09 01:55PM
  Re: gilarini mattology - 11/13/09 02:37PM
  Re: gilarini Lorenzo Ran Earlier 11/13/09 02:50PM
  Re: gilarini mattology - 11/13/09 04:46PM
  Re: gilarini SABAT! 11/13/09 05:06PM
  Re: gilarini ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/13/09 06:14PM
  Re: gilarini mattology - 11/13/09 08:22PM
  Re: gilarini ) Cupermcnewbster ( 11/13/09 08:54PM
  Re: gilarini ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/13/09 09:10PM
  Re: gilarini mattology - 11/13/09 09:53PM
  Re: gilarini phrick 11/13/09 10:13PM
  Re: gilarini mattology - 11/13/09 10:18PM
  Re: gilarini Freebird 11/13/09 11:34PM
  Re: gilarini mattology - 11/14/09 12:16AM
  Re: gilarini mattology - 11/14/09 02:43AM
  Re: gilarini Shay D 11/14/09 11:29AM
  Re: gilarini mattology - 11/14/09 01:52PM
  Re: gilarini mattology - 11/16/09 12:18AM
  Re: gilarini Jesse -B 11/17/09 10:03AM
  Re: gilarini mattology - 11/17/09 10:08AM
  Re: gilarini Brian Blazel 11/17/09 03:36PM
  Re: gilarini mattology - 11/17/09 03:43PM
  Re: gilarini Brian Blazel 11/17/09 07:22PM
  Re: gilarini mattology - 11/17/09 09:48PM
  Re: gilarini ) Cupermcnewbster ( 11/17/09 10:57PM
  Re: gilarini mattology - 11/17/09 11:45PM
  Re: gilarini clay 11/17/09 11:51PM
  Re: gilarini lkr 11/17/09 11:59PM
  Re: gilarini Ed 11/21/09 05:19PM
  Re: gilarini mattology - 11/21/09 09:04PM
  Re: gilarini spencer 11/21/09 10:50PM
  Re: gilarini Magurczek 12/09/09 03:09AM
  Re: gilarini ) Cupermcnewbster ( 12/09/09 03:36AM
  Re: gilarini mattology - 12/09/09 03:49PM
  Re: gilarini sunny 12/13/09 03:28AM
  Re: gilarini mattology - 12/13/09 03:31AM
  Re: gilarini Cappy 12/23/09 02:25AM
  Re: gilarini mattology - 12/24/09 11:09PM
  Re: gilarini Cappy 01/04/10 02:01AM
  Re: gilarini Los Dean 01/04/10 02:20PM
  Re: gilarini Cappy 01/04/10 08:47PM
  gilarini update mattology - 03/01/10 03:44AM
  Re: gilarini Eric Sabatino 01/04/10 09:05PM
  Re: gilarini mattology - 01/04/10 09:14PM
  Re: gilarini The Hebrew Hammer 01/04/10 10:15PM
  Re: gilarini ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 01/04/10 10:34PM
  Re: gilarini Los Dean 01/04/10 10:45PM
  Re: gilarini mattology - 01/04/10 10:48PM
  Re: gilarini mattology - 01/28/10 01:12AM
  Re: gilarini Southern Dandy JCams 01/28/10 01:35AM
  Re: gilarini ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 01/28/10 01:39AM
  Re: gilarini ) Cupermcnewbster ( 01/28/10 03:02AM
  Re: gilarini mattology - 01/28/10 03:30AM
  Re: gilarini Sunset Paul 01/28/10 05:02AM
  Re: gilarini aph1979 01/28/10 09:23AM
  Re: gilarini Crackstar X 01/28/10 10:42AM
  Re: gilarini mattology - 01/29/10 02:36AM
  Re: gilarini Lurker 01/29/10 02:52AM
  Re: gilarini Magurczek 01/29/10 10:17PM
  Re: gilarini Southern Dandy JCams 01/29/10 10:32PM
  Re: gilarini mattology - 01/29/10 11:03PM
  Re: gilarini Freebird 01/30/10 12:28AM
  Re: gilarini cocoloco 01/30/10 12:58AM
  Re: gilarini Los Dean 01/30/10 01:36AM
  Re: gilarini clay 01/30/10 10:55AM
  Re: gilarini Magurczek 01/30/10 03:14PM
  Re: gilarini Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 01/30/10 04:54PM
  Re: gilarini Southern Dandy JCams 01/30/10 04:57PM
  Re: gilarini Tony Gumble 01/30/10 10:04PM
  Re: gilarini . (Nick) 01/30/10 10:07PM
  Re: gilarini mattology - 01/31/10 03:27PM
  Re: gilarini brooks rayman 01/31/10 03:38PM
  Re: gilarini mattology - 01/31/10 04:46PM
  Re: gilarini . (Nick) 01/31/10 04:50PM
  Re: gilarini funk 01/31/10 06:17PM
  Re: gilarini mattology - 01/31/10 06:47PM
  Re: gilarini clay 01/31/10 08:02PM
  Re: gilarini mattology - 01/31/10 10:35PM
  Re: gilarini ezdasnowman!! 01/31/10 11:01PM
  Re: gilarini The Hebrew Hammer 01/31/10 11:06PM
  Re: gilarini mattology - 02/01/10 01:07AM
  Re: gilarini pauld 02/01/10 01:58AM
  Re: gilarini FlyByNight Taylor 02/01/10 02:07AM
  Re: gilarini Weak- End Justus 02/01/10 03:30PM
  Re: gilarini mattology - 02/03/10 03:55PM
  Re: gilarini Los Dean 02/03/10 04:59PM
  Re: gilarini mattology - 02/03/10 05:48PM
  Re: gilarini ezdasnowman!! 02/03/10 05:59PM
  Re: gilarini westseattleryan 02/03/10 08:04PM
  Re: gilarini mattology - 02/03/10 08:07PM
  Re: gilarini Jeremy (D) Bandit 02/03/10 08:20PM
  Re: gilarini ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 02/03/10 08:34PM
  Re: gilarini Cappy 02/06/10 09:55PM
  Re: gilarini mattology - 02/07/10 01:01AM
  Re: gilarini Jesse -B 02/07/10 08:27AM
  Re: gilarini mattology - 02/07/10 01:50PM
  Re: gilarini westseattleryan 02/08/10 08:45PM
  Re: gilarini westseattleryan 02/08/10 09:04PM
  Re: gilarini The Hebrew Hammer 02/08/10 09:52PM
  Re: gilarini westseattleryan 02/08/10 09:57PM
  Re: gilarini Los Dean 02/08/10 11:37PM
  Re: gilarini Flagrant - 02/09/10 01:03PM
  Re: gilarini Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/09/10 01:26PM
  Re: gilarini ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 02/09/10 02:31PM
  Re: gilarini Cold Trailer GARzan Justin 02/09/10 03:02PM
  Re: gilarini I<3WSR Gorilla-Steve 02/09/10 04:23PM
  Re: gilarini westseattleryan 02/09/10 03:29PM
  Re: gilarini Los Dean 02/09/10 04:16PM
  Re: gilarini I<3WSR mattology - 02/09/10 06:08PM
  Re: gilarini I<3WSR ) Cupermcnewbster ( 02/10/10 02:38AM
  Re: gilarini I<3WSR Dennis Kreeft 02/10/10 02:45PM
  Re: gilarini I<3WSR mattology - 02/11/10 10:27AM
  Re: gilarini I<3WSR Los Dean 02/11/10 02:35PM
  Re: gilarini I<3WSR ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 02/11/10 05:09PM
  Re: gilarini I<3WSR mattology - 02/12/10 10:11PM
  Re: gilarini I<3WSR Leedog 02/13/10 01:09AM
  Re: gilarini I<3WSR mattology - 02/13/10 02:37AM
  Re: gilarini I<3WSR ezdasnowman!! 02/13/10 12:29PM
  Re: gilarini I<3WSR cocoloco 02/13/10 04:27PM
  Re: gilarini I<3WSR Bill_O_MAtic 02/13/10 07:25PM
  Re: gilarini I<3WSR Southern Dandy JCams 02/13/10 10:45PM
  Re: gilarini I<3WSR marsh 02/13/10 11:15PM
  Re: gilarini I<3WSR marsh 02/13/10 11:19PM
  Re: gilarini I<3WSR fubar 02/14/10 01:07AM
  Re: gilarini I<3WSR mattology - 02/14/10 02:36AM
  Re: gilarini I<3WSR The Hebrew Hammer 02/14/10 03:38AM
  Re: gilarini I<3WSR mattology - 02/14/10 04:23AM
  Re: gilarini I<3WSR Kansas John 02/14/10 05:58AM
  Re: gilarini I<3WSR The Hebrew Hammer 02/14/10 01:27PM
  Re: gilarini I<3WSR clay 02/14/10 02:42PM
  Re: gilarini I<3 Cold Trailers Cold Trailer GARzan Justin 02/14/10 03:43PM
  Re: gilarini I<3 Cold Trailers mattology - 02/14/10 04:31PM
  Re: gilarini I<3 Cold Trailers Colinswoop . 03/01/10 05:57PM
  Re: gilarini I<3 Cold Trailers clay 02/15/10 10:39AM
  Re: gilarini update ezdasnowman!! 03/01/10 01:57PM
  Re: gilarini update Cold Trailer GARzan Justin 03/01/10 03:49PM
  Re: gilarini update Cold Trailer GARzan Justin 03/01/10 03:50PM
  Re: gilarini update mattology - 03/01/10 04:46PM
  Re: gilarini I<3 Cold Trailers mattology - 03/02/10 01:36AM
  Re: gilarini I<3 Cold Trailers Cappy 03/02/10 03:02AM
  Re: gilarini I<3 Cold Trailers durdan 03/02/10 05:24PM
  Re: gilarini I<3 Cold Trailers mattology - 03/04/10 06:45PM
  Re: gilarini I<3 Cold Trailers coco 03/04/10 07:08PM
  Re: gilarini I<3 Cold Trailers mattology - 03/04/10 07:17PM
  Re: gilarini I<3 Cold Trailers John Z. 03/04/10 11:10PM
  Re: gilarini Magurczek 03/05/10 01:16PM
  Re: gilarini mattology - 03/05/10 04:30PM
  Re: piston wear update The Hebrew Hammer 06/03/10 03:39AM
  Re: gilarini hawkns 03/05/10 04:34PM
  Re: gilarini mattology - 03/05/10 05:31PM
  piston wear update mattology - 03/07/10 03:09AM
  Re: piston wear update Dennis Kreeft 03/07/10 07:59AM
  Re: piston wear update mattology - 06/03/10 05:17AM
Click here to login.
