Forums / Moped Performance
ZA50+MK80 Port Matching
Mars™   (martian) — Nov 09, 2009 07:48PM
Anyone have any pictures of the port matching job done on this setup? I'm debating whether I would be better off matching fully and having to get material added to the case, or if I should just go as far as I can with the matching without cutting through the sides.
I would like to see some others' matching jobs if possible.
I have also been debating machining a sort of bolt-on shim thing to add material to the case instead of risking destroying the case.
Any thoughts on that?
Click here to login.
