Forums / Moped Performance
"KTM" clutch on e-50
human schwien (mad_maxi) — Nov 08, 2009 06:58PM
making puch clutches engage at high rpms means they won't last long. i've always heard stuff about people using these clutches, as well as, making them start with normal pedal/push start. using a lot of info i have found on here and some trial and error stuff we made this work. here is a step by step(with limited pictures) tutorial on making these clutches work on an e50.
1. first start with the clutch. they come from an s5 franco morini motor. i'm not quite sure why people call them "KTM" clutches, because i don't think they were actually on a ktm. they did however come on LEM and Cobra 50cc dirt bikes. you can make them engage up to 9,000 rpms if you want, and they have very close to 360 degree surfacing. these already fit on the puch crank taper with no modifications.
2. the main issue with making these work is that the o.d. of the clutch is much smaller than a puch clutch bell. using helpful knowledge from an old thread, i found that v1 clutch bells have the same o.d. as the clutch. so, we used a hydraulic press to press out the gear in the clutch bell. we didn't have to do this to a puch clutch bell, because drew's pinto ripped his off his old bell months ago. then, we found that the puch gear was a tad large for the v1 clutch bell. no problem, we lathed the v1 bell slightly larger on the inside. once everything matches you find a way to hold the gear in place/centered in the bell, and weld them together.
3. next, you pretty much just put it together. you need to use the v1 starter plate and clip. luckily friction material is on the starter plate instead of the clutch on the v1 making the rest of this easy. we had to grind a little down on the outside, as it was hitting on the clutch cover in spots.
a video of the bike in action is on our blog: here
  "KTM" clutch on e-50 human schwien 11/08/09 06:58PM
  Re: "KTM" clutch on e-50 spencer 11/08/09 07:18PM
  Re: "KTM" clutch on e-50 human schwien 11/08/09 07:21PM
  Re: "KTM" clutch on e-50 spencer 11/08/09 07:28PM
  Re: "KTM" clutch on e-50 mattology - 11/08/09 08:38PM
  Re: "KTM" clutch on e-50 human drew 11/08/09 08:40PM
  Re: "KTM" clutch on e-50 spencer 11/08/09 08:49PM
  Re: "KTM" clutch on e-50 human schwien 11/11/09 09:00AM
  Re: "KTM" clutch on e-50 j c 11/11/09 01:22PM
  Re: "KTM" clutch on e-50 Los Dean 11/11/09 04:28PM
  Re: "KTM" clutch on e-50 Jesse Stephenson 11/11/09 07:46PM
  Re: "KTM" clutch on e-50 human schwien 11/11/09 05:17PM
  Re: "KTM" clutch on e-50 naz 11/11/09 08:32PM
  Re: "KTM" clutch on e-50 sea lion 11/11/09 05:25PM
  Re: "KTM" clutch on e-50 orange post-its 11/11/09 05:54PM
  Re: "KTM" clutch on e-50 Los Dean 11/11/09 08:54PM
  Re: "KTM" clutch on e-50 Jesse Stephenson 11/11/09 09:34PM
  Re: "KTM" clutch on e-50 ) Cupermcnewbster ( 11/11/09 09:15PM
  Re: "KTM" clutch on e-50 Los Dean 11/11/09 09:28PM
  Re: "KTM" clutch on e-50 Los Dean 11/11/09 09:47PM
  Re: "KTM" clutch on e-50 justin turner 11/11/09 10:18PM
  Re: "KTM" clutch on e-50 human schwien 11/11/09 11:19PM
  Re: "KTM" clutch on e-50 human schwien 11/11/09 11:23PM
  Re: "KTM" clutch on e-50 naz 11/11/09 11:42PM
  Re: "KTM" clutch on e-50 Los Dean 11/11/09 11:59PM
  Re: "KTM" clutch on e-50 human drew 11/12/09 12:59AM
  Re: "KTM" clutch on e-50 vic 11/12/09 02:16AM
  Re: "KTM" clutch on e-50 ) Cupermcnewbster ( 11/12/09 02:44AM
  Re: "KTM" clutch on e-50 turd 11/12/09 06:12AM
  Re: "KTM" clutch on e-50 Schwieny 11/12/09 09:01AM
  Re: "KTM" clutch on e-50 tweeder 11/12/09 10:37AM
  Re: "KTM" clutch on e-50 human drew 11/12/09 11:08AM
  Re: "KTM" clutch on e-50 coco 11/12/09 11:42AM
  Re: "KTM" clutch on e-50 human schwien 11/12/09 04:08PM
  Re: "KTM" clutch on e-50 human schwien 11/12/09 04:12PM
  Re: "KTM" clutch on e-50 tweeder 11/12/09 04:16PM
  Re: "KTM" clutch on e-50 Mo Peds 11/12/09 05:43PM
  Re: "KTM" clutch on e-50 Mo Peds 11/12/09 05:44PM
  Re: "KTM" clutch on e-50 Mo Peds 11/12/09 06:06PM
  Re: "KTM" clutch on e-50 King Bengry 11/12/09 09:12PM
  Re: "KTM" clutch on e-50 human drew 11/12/09 09:32PM
  Re: "KTM" clutch on e-50 King Bengry 11/12/09 11:29PM
  Re: "KTM" clutch on e-50 Schwieny 11/12/09 09:46PM
  Re: "KTM" clutch on e-50 human drew 11/12/09 11:33PM
  Re: "KTM" clutch on e-50 Ryan 11/12/09 11:41PM
  Re: "KTM" clutch on e-50 ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/12/09 11:41PM
  Re: "KTM" clutch on e-50 human drew 11/13/09 12:35AM
  Re: "KTM" clutch on e-50 Jesse -B 11/13/09 08:10PM
  Re: "KTM" clutch on e-50 ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/13/09 12:43AM
  Re: Nick Amos 11/14/09 10:05AM
  Re: Jeremy osborn 11/14/09 10:56AM
  Re: "KTM" clutch on e-50 human drew 11/14/09 07:49PM
  Re: "KTM" clutch on e-50 fishstics 11/14/09 07:55PM
  Re: "KTM" clutch on e-50 Flagrant - 11/15/09 01:58AM
  Re: "KTM" clutch on e-50 Magic Johnson 11/15/09 04:04AM
  Re: "KTM" clutch on e-50 Los Dean 11/15/09 06:46AM
  Re: "KTM" clutch on e-50 Southern Dandy JCams 11/15/09 10:00AM
  Re: "KTM" clutch on e-50 human schwien 11/15/09 08:07PM
  Re: "KTM" clutch on e-50 human schwien 11/24/09 11:17PM
  Re: "KTM" clutch on e-50 Max Mojo 06/16/10 02:41AM
  Re: "KTM" clutch on e-50 vic 11/25/09 12:56AM
  Re: "KTM" clutch on e-50 turkey drew 11/25/09 11:07AM
  Re: Prick 11/25/09 12:36PM
  Re: turkey drew 11/25/09 01:02PM
  Re: Prick 11/25/09 01:18PM
  Re: Prick 11/25/09 01:20PM
  Re: Prick 11/25/09 01:23PM
  Re: vic 11/25/09 02:05PM
  Re: Prick 11/25/09 02:25PM
  Re: "KTM" clutch on e-50 Mo Peds 11/25/09 05:46PM
  Re: "KTM" clutch on e-50 Mo Peds 11/25/09 05:58PM
  Re: "KTM" clutch on e-50 vic 11/25/09 09:25PM
  Re: "KTM" clutch on e-50 Mike Thomas 11/25/09 09:53PM
  Re: "KTM" clutch on e-50 turkey drew 11/26/09 09:57AM
  Re: "KTM" clutch on e-50 turkey drew 11/26/09 09:58AM
  Re: ovc 01/25/10 09:20AM
  Re: Chris Rice 01/25/10 10:42PM
  Re: joey 01/26/10 05:57AM
  Re: PYTelliott 01/26/10 06:00AM
  Re: human drew 01/26/10 08:11AM
  Re: "KTM" clutch on e-50 Mo Peds 01/26/10 09:58AM
  Re: "KTM" clutch on e-50 human drew 01/26/10 10:15AM
  Re: "KTM" clutch on e-50 Mo Peds 01/26/10 10:18AM
  Re: "KTM" clutch on e-50 tweeder 01/26/10 10:29AM
  Re: "KTM" clutch on e-50 Mo Peds 01/26/10 10:33AM
  Re: "KTM" clutch on e-50 human drew 01/26/10 10:33AM
  Re: "KTM" clutch on e-50 Mo Peds 01/26/10 10:40AM
  Re: "KTM" clutch on e-50 trick METRIC 01/26/10 02:28PM
  Re: "KTM" clutch on e-50 human schwien 01/26/10 03:55PM
  Re: "KTM" clutch on e-50 human drew 01/26/10 05:12PM
  Re: "KTM" clutch on e-50 Gabe Bandit 01/26/10 05:34PM
  Re: "KTM" clutch on e-50 Cappy 01/26/10 08:57PM
  thread hijack trick METRIC 01/27/10 01:41AM
  Re: thread hijack mattology - 01/27/10 02:52AM
  Re: thread hijack ottoman 01/27/10 03:30PM
  Re: thread hijack Joey 02/05/10 06:41AM
  Re: thread hijack Joey 02/05/10 06:45AM
  Re: thread hijack human drew 02/05/10 04:09PM
  Re: thread hijack ) Cupermcnewbster ( 02/05/10 05:32PM
  Re: thread hijack Chris topher 02/06/10 07:42PM
  Re: thread hijack ovc 02/06/10 08:42PM
  Re: thread hijack human schwien 02/06/10 11:34PM
  Re: thread hijack ovc 02/07/10 08:38AM
  Re: thread hijack human drew 02/07/10 09:31AM
  Re: thread hijack Chris topher 02/07/10 01:25PM
  Re: "KTM" clutch on e-50 Schwieny 06/16/10 08:47AM
  Re: "KTM" clutch on e-50 Max Mojo 06/16/10 01:17PM
  Re: "KTM" clutch on e-50 humanDREW 06/16/10 09:07AM
  Re: "KTM" clutch on e-50 Mo Peds 06/16/10 09:23AM
  Re: "KTM" clutch on e-50 Mo Peds 06/16/10 11:04AM
  Re: "KTM" clutch on e-50 Max Mojo 06/16/10 04:28PM
  Re: "KTM" clutch on e-50 bowie82 06/16/10 05:26PM
  Re: "KTM" clutch on e-50 humanDREW 06/16/10 06:43PM
  Re: "KTM" clutch on e-50 Max Mojo 06/16/10 07:48PM
  Re: "KTM" clutch on e-50 chris 06/23/10 09:13PM
  Re: "KTM" clutch on e-50 chris 06/17/10 10:19PM
  Re: "KTM" clutch on e-50 human drew 06/24/10 09:37AM
  Re: "KTM" clutch on e-50 chris 06/24/10 01:24PM
  Re: "KTM" clutch on e-50 motobee 06/24/10 02:48PM
  Re: "KTM" clutch on e-50 chris 06/26/10 02:16PM
  Re: "KTM" clutch on e-50 bowie82 06/30/10 02:43PM
  UPDATE:: REAL KTM CLUTCH WORKS tim 01/27/11 03:14AM
  Re: UPDATE:: REAL KTM CLUTCH WORKS Mo Peds 01/27/11 03:37AM
  Re: UPDATE:: REAL KTM CLUTCH WORKS Mo Peds 01/27/11 03:45AM
  Re: UPDATE:: REAL KTM CLUTCH WORKS Mo Peds 01/27/11 03:48AM
  Re: "KTM" clutch on e-50 human drew 06/30/10 04:52PM
  Re: "KTM" clutch on e-50 human drew 06/30/10 04:54PM
  Re: "KTM" clutch on e-50 spencer 07/16/10 11:07PM
  Re: "KTM" clutch on e-50 Andy Haldeman 07/16/10 11:41PM
  Re: "KTM" clutch on e-50 Andy Haldeman 07/16/10 11:42PM
  Re: "KTM" clutch on e-50 spencer 07/17/10 12:42AM
  Re: "KTM" clutch on e-50 chief mycon 09/08/10 01:59PM
  Re: "KTM" clutch on e-50 coco 12/25/10 02:23AM
  Re: "KTM" clutch on e-50 frank 12/25/10 02:42AM
  Re: tim 12/31/10 04:32AM
  Re: Mo Peds 12/31/10 09:29AM
  Re: Cooper 12/31/10 02:03PM
  Re: westseattleryan 12/31/10 03:40PM
  Re: tim 12/31/10 08:28PM
  Re: UPDATE:: REAL KTM CLUTCH WORKS schwiendog 01/27/11 08:14AM
  Re: UPDATE:: REAL KTM CLUTCH WORKS tim 01/27/11 02:27PM
  Re: "KTM" clutch on e-50 Mo Peds 01/27/11 06:44PM
  Re: "KTM" clutch on e-50 Mo Peds 01/27/11 06:45PM
  Re: "KTM" clutch on e-50 tim 01/27/11 07:00PM
  Re: "KTM" clutch on e-50 tim 01/30/11 10:13PM
  Re: "KTM" clutch on e-50 tim 01/30/11 10:15PM
  Re: "KTM" clutch on e-50 tim 01/30/11 10:18PM
  Re: "KTM" clutch on e-50 Mo Peds 01/30/11 10:20PM
  Re: "KTM" clutch on e-50 tim 01/30/11 10:25PM
  Re: "KTM" clutch on e-50 ziggydeerguts 01/30/11 11:27PM
  Re: "KTM" clutch on e-50 Mo Peds 02/05/11 05:38PM
  Re: "KTM" clutch on e-50 RingringBANG ! 09/01/11 07:30PM
Click here to login.
