Forums / Moped Performance
Re: the greatest idea...ever?
Grey L (saabsonettguy) — Nov 07, 2009 03:09PM
Most mopeds inject oil into the intake manifold, so you would be injecting an un-metered extra amount of fuel. This injected fuel isn't even atomized, it'll be large droplets. The second problem is that oil injectors have a ball valve to prevent oil from leaking into your engine when the engine isn't running(the oil injection system is basically gravity fed). I think that the lower viscosity of the premix will allow it to leak much easier. If it does leak past the ball valve it will fill your crankcase full of fuel. I've had this happen with oil, and its not fun. In fact it put so much oil into the engine it hydro-locked. I'd say use it as intended, or remove it.
  the greatest idea...ever? SUNSET motobrokane 11/07/09 01:36AM
  Re: the greatest idea...ever? AirSoluble 11/07/09 01:50AM
  Re: the greatest idea...ever? spencer 11/07/09 02:30AM
  Re: the greatest idea...ever? AirSoluble 11/07/09 02:32AM
  Re: the greatest idea...ever? Britchez 11/07/09 02:52AM
  Re: the greatest idea...ever? Mike Bartell 11/07/09 04:00AM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 04:19AM
  Re: the greatest idea...ever? ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/07/09 04:27AM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 04:50AM
  Re: the greatest idea...ever? Jesse Stephenson 11/07/09 05:39AM
  Re: the greatest idea...ever? Los Dean 11/07/09 07:01AM
  Re: the greatest idea...ever? Jimmy Stucky 11/07/09 09:55AM
  Re: the greatest idea...ever? mike 11/07/09 10:47AM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 12:07PM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 12:12PM
  Re: the greatest idea...ever? zeke 11/07/09 12:18PM
  Re: the greatest idea...ever? StronGAR 11/07/09 12:21PM
  Re: the greatest idea...ever? Seniorita magicgato 11/07/09 12:43PM
  Re: the greatest idea...ever? Seniorita magicgato 11/07/09 12:53PM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 01:38PM
  the greatest idea...ever? jerry76 11/07/09 02:11PM
  Re: the greatest idea...ever? Jesse Stephenson 11/07/09 02:46PM
  Re: the greatest idea...ever? ottoman 11/07/09 02:47PM
  Re: the greatest idea...ever? Grey L 11/07/09 03:09PM
  Re: the greatest idea...ever? Jesse Stephenson 11/07/09 03:38PM
  Re: the greatest idea...ever? rofman 11/07/09 07:13PM
  Re: the greatest idea...ever? Jesse Stephenson 11/07/09 07:37PM
  Re: the greatest idea...ever? Tate 11/07/09 08:25PM
  Re: the greatest idea...ever? zeke 11/07/09 10:22PM
  Re: the greatest idea...ever? ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/08/09 12:43AM
  Re: the greatest idea...ever? zeke 11/08/09 12:50AM
  Re: the greatest idea...ever? vic 11/08/09 01:09AM
  Re: the greatest idea...ever? Graham Motzing 11/09/09 07:06PM
Click here to login.
