Forums / Moped Performance
Re: the greatest idea...ever?
Jesse Stephenson ( jesses) — Nov 07, 2009 05:39AM
Ugg....
1. Reducing/changing the amount the pump flows is pretty infeasible
2. Knowing the exact amount that you have then changed it to so that you can accurately measure the oil for the tank is also going to be hard
3. Kitting a bike and trying to use the oil injection does not work very well because when you change the jet sizes on the carb you cannot change the predetermined metered oil amount the injector supplies, therefore making previous alterations and calculations pretty useless.
4. If you were going to go through the trouble of changing the metering of the pump then why make it go less and add oil to the tank when you could make it add more and maintain the actual function of the pump, i.e. not having the premix
5. Running a rpm dependent pump on a kit when throttle positioning will not be full open all the time again makes the fuel/oil ratio off at different rpms and throttle positions, with kits being more prone to seizure and damage from inadequate oil flow it only compounds the issue.
When I first read this I though it was a joke thread.
  the greatest idea...ever? SUNSET motobrokane 11/07/09 01:36AM
  Re: the greatest idea...ever? AirSoluble 11/07/09 01:50AM
  Re: the greatest idea...ever? spencer 11/07/09 02:30AM
  Re: the greatest idea...ever? AirSoluble 11/07/09 02:32AM
  Re: the greatest idea...ever? Britchez 11/07/09 02:52AM
  Re: the greatest idea...ever? Mike Bartell 11/07/09 04:00AM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 04:19AM
  Re: the greatest idea...ever? ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/07/09 04:27AM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 04:50AM
  Re: the greatest idea...ever? Jesse Stephenson 11/07/09 05:39AM
  Re: the greatest idea...ever? Los Dean 11/07/09 07:01AM
  Re: the greatest idea...ever? Jimmy Stucky 11/07/09 09:55AM
  Re: the greatest idea...ever? mike 11/07/09 10:47AM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 12:07PM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 12:12PM
  Re: the greatest idea...ever? zeke 11/07/09 12:18PM
  Re: the greatest idea...ever? StronGAR 11/07/09 12:21PM
  Re: the greatest idea...ever? Seniorita magicgato 11/07/09 12:43PM
  Re: the greatest idea...ever? Seniorita magicgato 11/07/09 12:53PM
  Re: the greatest idea...ever? SUNSET motobrokane 11/07/09 01:38PM
  the greatest idea...ever? jerry76 11/07/09 02:11PM
  Re: the greatest idea...ever? Jesse Stephenson 11/07/09 02:46PM
  Re: the greatest idea...ever? ottoman 11/07/09 02:47PM
  Re: the greatest idea...ever? Grey L 11/07/09 03:09PM
  Re: the greatest idea...ever? Jesse Stephenson 11/07/09 03:38PM
  Re: the greatest idea...ever? rofman 11/07/09 07:13PM
  Re: the greatest idea...ever? Jesse Stephenson 11/07/09 07:37PM
  Re: the greatest idea...ever? Tate 11/07/09 08:25PM
  Re: the greatest idea...ever? zeke 11/07/09 10:22PM
  Re: the greatest idea...ever? ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/08/09 12:43AM
  Re: the greatest idea...ever? zeke 11/08/09 12:50AM
  Re: the greatest idea...ever? vic 11/08/09 01:09AM
  Re: the greatest idea...ever? Graham Motzing 11/09/09 07:06PM
Click here to login.
