Re: Removing Gila Exhaust Studs
Socket cap screw is the proper name for the fastener. It's what you see at the hardware store, for example.
from wikipedia under screw:
Socket cap screw
Also known as a socket head cap screw, socket screw or Allen bolt, this is a type of cap screw with a hexagonal recessed drive. The most common types in use have a cylindrical head whose diameter is nominally 1.5 times (1960 series design) that of the screw shank (major) diameter. Counterbored holes in parts allow the screw head to be flush with the surface or recessed. Other head designs include button head and flat head, the latter designed to be seated into countersunk holes. A hex key (sometimes referred to as an Allen wrench or Allen key) or hex driver is required to tighten or loosen a socket screw. Socket screws are commonly used in assemblies that do not provide sufficient clearance for a conventional wrench or socket.
Socket cap screw
| Subject | Written By | Posted |
