Forums / Moped Performance
Re: n00b Q
WillD ( julian) — Nov 05, 2009 09:07PM
A properly modified kittened moped engine will last longer than a poorly maintained stock motor. There are also many different levels of kits, some are barely more powerful than stock, and some will give you insane crank-bending power and absurd rpm. Will makes a good point; if you break something, you can replace it for relatively cheap, I mean, whole running mopeds can be had for a couple hundo any time. So I would actually encourage you to modify your ped until it breaks, then fix it and repeat.
If you aren't breaking stuff you aren't trying hard enough.
  n00b Q zachini 11/05/09 05:31PM
  Re: n00b Q Sunset Paul 11/05/09 06:46PM
  Re: n00b Q WillD SWOOP 11/05/09 08:11PM
  Re: n00b Q zeke 11/05/09 08:32PM
  Re: n00b Q WillD 11/05/09 09:07PM
  Re: n00b Q rofman 11/05/09 09:53PM
Click here to login.
