Forums / Moped Performance
Re: new kit,carb,dies when given throttle
rofman (roffman) — Nov 06, 2009 07:31PM
I set up 4 polinis with 15mm bings, foam filter, performance exhaust. THIS IS THE SET UP 88# jet clip all the way down (rich) set the stator all the way advance gap points 19- 20 thou. or dremel stator holes bigger a few mm then use less gap If this set up does not work you have a air leak or something wrong
Click here to login.
