Re: Jetting with weather changes
Soul That depends on what your 80 deg whether set up is #1 #2 or #3 ?
#1 will need a hotter plug first then plug chop, some may need up jetting to.
#3 may or may not need up jetting.
#3 will need a fatter/richer jet first then plug chop,some may need a hotter plug to.
Ck the for the dark ring at the base of your plug tip.
You wont your dark ring to be 2mm warm plug to 4mm cool plug.
Bat out
Bat out
