Forums / Moped Performance
Re: Jetting with weather changes
Crazy Wayne Treats Rock's (powerchair) — Nov 06, 2009 04:32PM
Yes Nickerbockerif you go to hot and or to lean you can seize.
A hotter spark plug will rise eng temp 10F to 20F deg's and bring things back up to temp on cold days.
The longer hotter tip, plus the bigger charge of air & gas in the plug housing.
Gives a bigger/hotter primer charge.
If your plug is to cold it will look to rich or it fouls up.
As long as uoy have dark ring 2mm wide at the base of your spark plug tip your not to hot.
If it's to hot it will reed lean, with no dark ring 2mm wide at the base of your spark plug tip.
You need to running at temp before you rejet.
On HOT HOT days you need a colder plug to cool things down.
Bat out
  Jetting with weather changes soulremedy2 11/04/09 09:38PM
  Jetting with weather changes Crazy Wayne Treats Rock's 11/04/09 09:46PM
  Re: Jetting with weather changes Britchez 11/04/09 09:47PM
  Re: Jetting with weather changes Josh Schutz 11/04/09 10:10PM
  Re: Jetting with weather changes Crazy Wayne Treats Rock's 11/04/09 10:26PM
  Re: Jetting with weather changes justin turner 11/04/09 11:08PM
  Re: Jetting with weather changes tweeder 11/05/09 10:14AM
  Re: Jetting with weather changes soulremedy2 11/05/09 01:28PM
  Re: Jetting with weather changes Shay D 11/05/09 01:54PM
  Re: Jetting with weather changes soulremedy2 11/05/09 05:42PM
  Re: Jetting with weather changes Britchez 11/05/09 06:22PM
  Re: Jetting with weather changes soulremedy2 11/05/09 08:15PM
  Re: Jetting with weather changes Britchez 11/05/09 08:53PM
  Re: Jetting with weather changes Andy Haldeman 11/05/09 08:51PM
  Re: Jetting with weather changes soulremedy2 11/05/09 09:21PM
  Re: Jetting with weather changes Britchez 11/05/09 09:27PM
  Re: Jetting with weather changes Josh Schutz 11/06/09 03:31AM
  Re: Jetting with weather changes Crazy Wayne Treats Rock's 11/06/09 04:32PM
  Re: Jetting with weather changes jerry76 11/07/09 02:27PM
  Re: Jetting with weather changes Crazy Wayne Treats Rock's 11/08/09 02:38PM
  Re: Jetting with weather changes soulremedy2 11/06/09 11:43AM
  Re: Jetting with weather changes chris†opher k 11/06/09 12:18PM
  Re: Jetting with weather changes timo 11/06/09 03:41PM
  Re: Jetting with weather changes Lee 11/06/09 11:33PM
  Re: Jetting with weather changes soulremedy2 11/08/09 03:16PM
  Re: Jetting with weather changes Crazy Wayne Treats Rock's 11/08/09 05:32PM
  Re: Jetting with weather changes Crazy Wayne Treats Rock's 11/08/09 06:38PM
Click here to login.
