Forums / Moped Performance
maxi w/ 12mmBing+hi flow foam filter = ? jet size?
jimmybaltimore (jimmybaltimore) — Nov 04, 2009 05:43PM
puch maxi sport two speed with a stock 12mm bing carb.
standard jet is a 50 for this carb but i've got a 52 and its running slow (22-25mph). i figure if i'm getting a new jet anyway, i might as well get a new filter also and up the jet to match the filter rather than lower the jet to the stock filter.
i'm keeping the stock pipe so i'm not expecting much boost but for $20-25 it seems like it would be worth it if i get any jump at all.
so here's the question. any thoughts on what size jet i should get? i'm thinking somewhere in the mid 60's. i'v attached a pic of the filter i'm prob getting. i live in Baltimore and its getting pretty cold out if that makes any difference.
thanks for the help
  maxi w/ 12mmBing+hi flow foam filter = ? jet size? jimmybaltimore 11/04/09 05:43PM
  Re: maxi w/ 12mmBing+hi flow foam filter = ? jet s rofman 11/04/09 06:58PM
  Re: maxi w/ 12mmBing+hi flow foam filter = ? jet s WillD SWOOP 11/04/09 07:51PM
Click here to login.
