Forums / Moped Performance
NC50 Problem - perf filter, 15mm carb, gut exhaust
Matthew Chedda (supremo13) — Nov 02, 2009 10:43PM
1980 Honda Express NC50 - 6,000mi - Stock setup ran great! Hit 28.
I gutted a stocked exhaust, installed a 15mm Dellorto replica carburetor, upjetted to a .0280 jet, installed a K&N style air filter, grinded out a reed plate a tiny bit with the stock petals.
My problem is I'm only going 2 mph faster then my stock set up.
What can I do to troubleshoot this issue?
  NC50 Problem - perf filter, 15mm carb, gut exhaust Matthew Chedda 11/02/09 10:43PM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh rofman 11/02/09 11:04PM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Matthew Chedda 11/02/09 11:19PM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh rofman 11/03/09 12:25AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Matthew Chedda 11/03/09 12:30AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh rofman 11/03/09 12:46AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/03/09 12:51AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Matthew Chedda 11/03/09 12:54AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/03/09 12:55AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh rofman 11/03/09 12:57AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Matthew Chedda 11/03/09 01:02AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Luke 11/03/09 01:25AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Matthew Chedda 11/03/09 01:41AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Luke 11/03/09 01:55AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh ottoman 11/03/09 02:39AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Matthew Chedda 11/03/09 02:51AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh ⊙△⊙ Ⓜⓔⓐⓝ Ⓝⓐⓢⓗ ⊙△⊙ 11/03/09 04:24AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh doppelkolben 11/03/09 01:12PM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Matthew Chedda 11/04/09 02:35AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Matthew Chedda 11/04/09 10:53AM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh derek 11/04/09 12:36PM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh Rick 11/04/09 12:55PM
  Re: NC50 Problem - perf filter, 15mm carb, gut exh thesatntmatador 04/25/10 07:20PM
Click here to login.
