Forums / Moped Performance
Re: What am I do wrong?
trick METRIC ( walt) — Nov 04, 2009 12:38AM
Besides not using ing? Increasing the carb size by 3mm is not going to increase your top speed by a noticeable amount when you're pushing 300lbs. You'll need a much bigger engine and carb, or you could go the cheaper route and drop 100lbs from the load it's pulling.
Click here to login.
